Ricoh Aficio 1027 All-In-One Laser Printer Logo
Diye Carbala Posted on Feb 02, 2014
Print SP & Scan SP are not avaible
Print SP & Scan SP are not avaible in SP Mode only Copy SP is fonctionning.In the main board also only the button copy is on.The scan & print button are off What can i do to make them fontionning. Help Please
ZHAM HUEL
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Mar 04, 2014
ZHAM HUEL
Contributor
Level 1:
New Friend:
Answers
13
Questions
Helped
5784
Points
16
Check f the printer and scanner kit r installed!
2 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Oct 04, 2008
SOURCE: Functional Problem SC 302
SC 302 has to do with you charge corona wire.  It's unrelated to the toner spill.  It could be a bad conora wire.  Sometimes it's the power supply.  There could be a lot of troubleshooting and repair to do on this one, you might want to contact a dealer in your area since the have the right tools for the right job.
Anonymous
  • 32 Answers
  • Posted on Apr 03, 2009
SOURCE: Functional Problem SC321-00
the sc320 code would indicate that the polygon motor should be replaced. when you turn on the machine, the normal high pitch buzz will not be there the motor is not spinning up. that's the reason for the blank copies.
the sc321 code is a "no laser writing signal (f-gate) error". which would caused by the polygon motor not spinning.
replace the polygon motor.
Brother dcp-7055 self diagnostic
Go to the Maintenance Mode by pressing Pressing "Menu, *, 2, 8, 6, 4". If you done it correctly, the printer will beep, lights will flash and the control panel will read Maintenance.
After it Press 9,9 and it will reboot and start its normal reset procedure.
If it still not work, then there may be the problem with fuser or main board. Check both one-by-one. This may solve the problem.
Continuous jam paper feed cl3500n
I THINK THE NUMBERS BUTTON HAD PROBLEM, TRY TO CHANGE THE NUMBERS BOARD & SEE IF THE PATTERN STILL PERSIST. IF THE PATTERN PERSIST ALTHOUGH YOU INSERTED NEW NUMBER BOARD, THEN YOU HAS TO GO IN SP MODE TO CHANGE PRINT SETTING
Code error e54 copier.i need the reset codes
- Possible Causes -
· Thermistor short
· Defective ac drive board
· Defective main board
· Fusing harness shorted
To reset code :
1. Turn on the main switch.
2. Enter "71" by using the numeral keys.
3. Press and hold the Clear/Stop key until a dot (·) appears in the top left
corner of the Copy Counter and then release it.
4. Press the Clear/Stop key again and then press the Lighter key.
NOTE: "5" will blink in the Copy Counter to show that the SP mode has
been accessed.
5. Enter the desired SP mode number using the numeral keys.
When the E52, E53, or E55 conditions occur, for safety reason
they cannot be cleared by turning off and on the main switch. The
following procedure must be performed to clear these service call
conditions:
2. Turn DPS 101-1 on and off.
3. Turn the main switch off and on.
1helpful
My copier uses ricoh 320 toner, it is black en white and its displaying error code e 54. what are the reset codes.
- Possible Causes -
· Thermistor short
To reset code :
been accessed.
When the E52, E53,E54 or E55 conditions occur, for safety reason
conditions:
2answers
I need to replace hard drive for a ricoh copier 1045. How can I get the software for the hardrive, and what is the maximum size of the hard drive?
No need for software. The standard hard drive size is 10GB. I don't remember the exact limit but the machine will only recongnize a certain amount so it will do you any good to buy a larger capacity drive. Just get the smallest/cheapest one and you'll be fine. These take the smaller "laptop" size drive in case you did not know. Other than that just install the new drive and let the machine do the setup. If your old drive failed then keep in mind you will have lost any document server files, scan destination or fax destination info and will have to re-enter that info.
Good Luck
1helpful
2answers
I have a RICOH FT 4022 Copier and when I switch it displays U 6
Ricoh 4022, 4027 Код ошибки Описание C1 Front door open C2 Exit door C3 Cassette cover C4 LCT cover C5 Sorter open or not latched to machine, or fuse 304 on DC power board C6 ADF cover C7 Right side cover E101 Exposure lamp too long E103 Frequency problem E120, 121 Scan home problem E124 Scan drive problem E140 Lens home, or fuse 303 on DC board E141-143 Lens home sensor, fuse 303 on DC board E144, 145 Mirror sensor, fuse 303 on DC board E191 Image density sensor error E302 Charge roller problem or HVT problem E346 Bias loss E351 Image density sensor problem E352 TD sensor error E353 Vsp problem. Dirty or bad image density sensor E354 Vsg problem. Same as E353 E355 Toner density sensor problem E356 Same as 355 E405 Transfer belt or charge roller drive E440 Main drive E442 Drum charge thermistor E501 Upper lift motor E502 Lower lift motor E503 1st tray motor E504 2nd tray motor E505 3rd tray motor E506 Tray main motor drive problem E507 LCTl lift motor E522-525 Jogger sensor E541 Fuser thermistor E542 Fuser temperature too low E543 Fuser temperature too high E544 Fuser temperature too high E547 Fuser lamp won't shut off E548 Fuser temperature too high or too low E620 Communication problem between main board and ARDF E621 Communication problem between main board and sorter E623 Communication problem between main board and paper trays E720 Sorter stapler timing roller sensor E721 Sorter stapler bin lift sensor E722 Sorter stapler jogger sensor E723 Sorter stapler grip sensor E724 Sorter stapler error E900, 901 Copy counter U2 Key counter U6 Fuser unit not installed properly U7 Duplex unit
2helpful
3answers
Copier problume.
return SP1-902-1 to 0. Then, the SC will
be cleared.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
