Replace the magenta image unit drum and developer units
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: The Bizhub C351 is printing the colours
print off halftone for each colour
utility/counter,metercount,stop.0.0.stop.0.1test mode.halftone.cmyk start.this will print off each colur, the "failed" one will be easy to see
SOURCE: Konica bizhub 6500 printing pink where white
Magenta image unit mite be bad
SOURCE: My office has the bizhub
Hi the machine could be defaulted to print from the main trays if you have the same type paper being fed from the manual feed same size paper then it will automatically take it from the default trays
IF you take the paper out of the trays and put it only in the manual feed will it print and take it from the manual feed also you have to tell the machine when you use the manual feed what size and type of paper is in the manual feed once you tell it what paper and type of paper like card stock you then need to make sure when you go to print that it is set on your computer with manual feed and type of paper must match what is set on machine
SOURCE: when i print label in bizhub c360 i put the label
Make sure the bypass tray is set to the correct size in the drivers.
