Posted on Feb 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Konika minolta bizhub 215 error code m2
How to remove error code M2
Clement Williams
Level 2:
New Friend:
  • Expert 91 Answers
  • Posted on Feb 05, 2014
Clement Williams
Expert
Level 2:
New Friend:
Answers
91
Questions
Helped
19022
Points
113
You need to go into the service mode and then reset the supplies life counter.
3 Related Answers
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Jan 01, 2011
SOURCE: Konica Minolta bizhub 163 Display
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
mochicas
  • 26 Answers
  • Posted on Feb 21, 2009
SOURCE: Driver utility of Konika Minolta Bizhub 162
Use the bizhub 180 same family
driver
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Jun 19, 2010
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
question too vague.
make? model?
example:
Re: Konika Minolta BizHub 163 - Error Code? M2
• To display the count of the supplies life counter.
When the counter reaches "0", life 1 will be detected and maintenance call M2 will appear.
The initial value is 40,000, and the countdown system is used.
Use Setting/Procedure
• To clear the count, use [CLEAR DATA] of the Service Mode.
2answers
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
What would be the genuine problem when konica minolta bizhub 215 shows maintainence call(m2)
Procedure
1. Press the COUNTER.
2. Press the following keys in this order:
STOP 0 0 STOP 0 1
3. Enter the code number corresponding to the function to be used from the KEYPAD.
4. Press the START.
<Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
How to solve M2 in bizhub 164
Konika Minolta BizHub 163 - Error Code M2
Press the Utility button,
then Stop 0 0
then press again Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
KONIKA MINOLTA BIZHUB 215 ERROR M2
replace the drum and developer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2helpful
Konika minolta bizhub 164 how to enter into service mode
KONOCA MINOLTA 164
ERROR FOR MAINTANANCE CALL(M2) ,PLEASE SOLVTHE PROBLEM
6helpful
21helpful
3answers
How can i reset m2 bizhub 211
I Have a Konika Minolta bizhub 211. I had been trying this solution for repairing m2 call. but the code is appear till now. anyone help me. please give me solution step by step.
Thanks
3helpful
6answers
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
