It all started when I tried to copy counters strike from mu mom's laptop to be paste in our desktop.. When I inserted the usb, it shows strange symbols that can't be read and it cannot be formatted. I inserted it again on my mom's laptop, the it said it needs scan and fix. After that, it goes baCK TO normal.. and I formatted the usb. When I tried to copy a movie from my friend's laptop, first it went fine but at the last 10 sec. a message popped out and said there's an error.. so I skipped it... When I opened the movie folder in the usb, it happened again.. strange symbols appeared again.. it can't be read.. now I can't put large files on my usb,coz it'll only result to that .. making its 8GB useless.
Sounds like there are sectors of the drive are failing. Chkdsk can help mark those as not usable. If drive is old and problems persist then consider getting a new one.
Can the files be copied successfully to the hard drive of another machine?
I also recommend at least trying ChkDsk on the USB.
Try running ChkDsk to check your drive for errors. Right-click your Drive icon/ Properties/ Tools/ Error Checking. Try it first by not checking either box (this will run it in a Read-only mode) to see if it flags any hard drive or file problems. If it does, restart it by ticking both boxes, and rerun it to allow it to attempt to fix any found problems.
Data recovery.
The first link is freeware, the others are free to try before purchase. The last two are a slightly better product in my opinion.
PC Inspector
http://www.pcinspector.de/default.htm?language=1
GetDataBack
http://www.runtime.org/hints.htm
Data Recovery tools for Windows 98/NT/2000/XP/2003 Server/Vista/Windows 7
http://www.restorer-ultimate.com
Find a new one. It might be worth nothing.
SOURCE: Please insert a disk into Drive E
Transcend provides a online recovery tool.just download that and format your pendrive with it.....that will solve your problem 100%.....
SOURCE: unable to open my 32GB transcend USB pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
SOURCE: TDK usb flash drive 8GB can not hold more than 5GB
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
2. Format Flash Drive
