HP Compaq WF1907 Monitor Logo
A
Anonymous Posted on Feb 02, 2014
Customizing screen resolution - HP Compaq WF1907 Monitor
How do I change the desktop text, icons and bars back to 100% from 500% in Windows 8.1?
Hi Cindy
You have set a customer DPI scale for your display.
Right Click on desktop
Choose "Screen Resolution"
Click on link that says "Make Text and other items larger or smaller"
Click on link that says "Set custom text size (DPI)"
Adjust the scale back to 100%
Apply the changes and all should be well.
Regards
Andrew
Make the text on your screen larger or smaller Microsoft Windows Help
How do i increase the screen resolutions for the lg we-32Q10IP
I am fairly sure in VGA it is a fixed resolution---give LG a call with the model number and see how smart their customer service people are.
1helpful
How do i hook up my ps3 with tv through hdmi as it keeps goin to blue screen
  1. Connect the PS3 standard composite video connector (yellow RCA plug) to the TV composite input and switch the TV to that input. Leave the HDMI cable connected.
  2. Make sure the PS3 is off. Turn it on and hold the power button until you get two beeps (at least 5 seconds). The PS3 navigation screen should be shown on the TV. If not, switch the TV back to HDMI; the screen should be displayed at 480i resolution.
  3. Go to the settings menu. Select Display Settings, then Video Output Settings, then press the X button on your controller.
  4. The on-screen instruction should be "Select the type of input on your TV." Select HDMI, then press the '> (solid right triangle) button on your controller.
  5. You will be offered the choice of Automatic or Custom settings. Try Automatic first (if there is a problem at the end, start over and pick Custom the second time).
  6. Press the X button. You will get a screen asking you to confirm the changes. Press the X button again to confirm.
  7. You may get a screen asking for the resolution setting. IMPORTANT: if your TV's maximum resolution is 720p or lower, do not pick a higher resolution. The TV may not display properly or may not display at all (blue screen). Pick the highest resolution your TV can display.
  8. Confirm this by selecting "Yes" and pressing the X button.
  9. The settings list should now read Connector Type HDMI; Resolution Standard (NTSC); 480p; 720p; 1080p (if applicable). Press the X button to confirm.
  10. You may be offered a choice of audio outputs; you can use HDMI or something else, depending on your setup. Confirm the setting and press X one more time.
At this point, the PS3 should send its signal to the HDMI port following restart. If your TV has more than one HDMI input, make sure you select the one connected to the PS3.
How can I increase the text(font) size of my toshiba satellite laptop
The easiest way to do this is to right click your mouse on the desktop of your computer, and click properties or customize (depending whether you have windows xp or vista/7) and under the setting and screen resolution, lower the screen resolution. The lower the screen resolution, the larger things will appear on the screen
1helpful
What is the combination of keys (shortcut) to change the screen resolution (not orientation).
There is no Fn-Fx key combination to change screen resolution (at leat on my R10 running Windows XP. Even if you create a shortcut to open the graphics properties you still have to open the relevant tab manually to change resolutions.
You can open the Intel Extreme Graphics 2 for mobile icon on the tray, go to the graphic properties change the resolution and save as a scheme. With a customized scheme defined you will be able to click the Intel Graphic properties and select that scheme. But be careful, your tablet pen will no longer be calibrated with the available screen area.
I tried on my R10 (native resolution 1024x768) and all I could select was 800x600@ 60Hz.
Input not supported error
The native resolution for the x193w monitor is 1440x900. The monitor will only allow certain resolutions. You may need to create a custom resolution using the nvidia control panel.
Goto:
advanced options display change resolution customize create custom resolution horizontal pixels : 1440 vertical lines 900 refresh I belive is either 75 or 60. Whichever looks better scan type: progressive
1helpful
Please tell me what kind of video format works on my lggd510 ,because i tried with mp3,3gp,mp4 and didn't worked. tell me please can i see mouvies on my phone?
dear chellu
lg gd510 works with 3gp and mpeg4 format. some times mpeg4 formatted videos cannot be played due to resolution problem. while in full screen mode it doesn't give complete full screen effect, while playing 3gp videos.
it is better to convert videos using "ANY VIDEO CONVERTER" FREE to download. it is a customized resolution converter. choose resolution as 400*240. use customized mpeg4 format. more support log on to http://www.neonetcrammer.blogspot.com
3helpful
5answers
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
1helpful
My playstation screen goes blank when i put a blue ray disk in
Excerpt from the PlayStation 3 Manual:
There is no picture on the TV screen.
*If the resolution of the video content is not supported by the TV in use, when the video is played the screen may go blank. If this happens, go to the screen for selecting the resolution in the system's video output settings, select "Custom" and then select all the resolutions that are supported by the TV.
Liquid video monitor trouble
Hi, the way your describing the problem it sounds like you don't have any video drivers installed in your machine, hence the computer is using a generic video driver with very limited resolutions. Try using Windows Update, when it asks you to do express or custom, choose custom and under hardware you should see your video drivers there. If not post the make and model of your PC and I'll help you find the drivers.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
