If this unit dies under load conditions, decrease your load and try it again.
If this happens under no-load conditions, check your fuel supply. Start with the filters, then check pressure and flow.
many generator problems is in the carburetor when you put a load the engine requires much more fuel and air most likely it's your carburetor jet and fuel tube are resticted especially if you had the generator stord for quite some time
the air conditioner is over loading generator, and safe shuts it off so it doesn't ruin generator windings, the a/c might have worked with it, but as they wear the need more power to start up
Hello. I'm sure that you've checked your air filter, so check the pinhole vent on the fuel filler cap. Next time it dies, immediately crack the cap and listen for the sucking sound of air rushing into the tank. If you hear this, clean the cap!
does it have original oil in it? if so they use a lighter weight oil than recommended for engine break in. change your oil and filter and see if that doesnt solve it.could be thinning out loosing pressure when hot. i have seen this beofore.. :)
