SOURCE: sony trinitron wega 36 inch
break the wega into tiny little pieces and it's easier to get out of your house!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
SOURCE: Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
SOURCE: STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I
have over 10 years experience in electronic tech
support.
I
know this isn't what you want to hear, but the problem you've
described can't be fixed with troubleshooting.
Your TV
will have to be repaired. There is a part that has developed a defect
and needs to be replaced. If you're still in warranty, the TV will be
repaired at no charge to you. The warranty would likely be at least
one year from the date of purchase from the manufacturer. If you
purchased an extended service
plan
they will repair the TV at no charge as well.
If the TV is no
longer in warranty, it will likely cost a minimum of $150 parts and
labor. This is assuming that you only need one circuit
board
or small part. If the problem is more than one of the circuit boards,
the price of repair could go much higher.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
