SOURCE: will not stop regenerating water keeps running
Check the units drain filter. If clogged up it will make this unit run constantly
SOURCE: Culligan Estate 2 Model 01010091. Back wash will not stop.
The back flow filter is clogged. It will need to be cleaned out. When it is clogged the pressure reverses so the valves will stay open to clean without shutting off
SOURCE: Culligan 01010091 (mark 89) softener will not auto
clean the drainage filter then it will work correctly again
SOURCE: Culligan Gold series softnerdrain line runs constantly in street.
The main piston/sealpack is frozen up and needs to be replaced. There is a retrofit kit available from Culligan to repair this issue. The reason it stops when bypassed is the water is shutoff to unit.
RJ
SOURCE: Culligan Super-S model 405AA38-556 C
It normally is under pressure. There is a "check ball" in the tube to prevent water from coming out of the tube in service. The feed tube has to be flooded with water in service position so when system goes in to draw cycle vacuum is created in the tube to draw bleach. You may have a plugged eductor assembly or feed tube may be restricted.
RJ
