GE Profile Spacemaker Over-the-Range Microwave Logo
A
Anonymous Posted on Aug 19, 2017
Microwave made noise when it was not in use.
Months ago I came home to my microwave making continuous, rhythmic grinding noises when it was not in use. I unplugged it and have left it unplugged for months. Today I decided to plug it back in before going out to buy a new one. It is not making any noise and I heated water and it seemed to work fine. I'm wondering what may have caused the noise and if I need to buy a replacement?
acmservice
Level 2:
Sergeant:
  • Expert 270 Answers
  • Posted on Aug 24, 2017
acmservice
Expert
Level 2:
Sergeant:
Answers
270
Questions
0
Helped
85743
Points
627
It depends what was making the noise. a bad door switch could cause the turntable motor and the fan to fun. If is heating it may still be worth repairing. I would check the door switches. See if you notice any browning around the plastic insulators where the wires plug onto the switches. If so, you will need to replace bad switch and run new wires and connectors to the new switch too.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Mar 23, 2007
SOURCE: Turntable Grinding Noise
It will need a new turntable motor. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on May 01, 2007
SOURCE: GE over the range microwave making grinding noise
This sounds like the stirrer. If it sticks or stops, the microwaves can damage or destroy it. You may have a bad stirrer or magnetron. There is an important bulletin that covers these problems. To see if yours is covered, see: http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf If you need more help, please follow-up.
Anonymous
  • Posted on Jan 08, 2008
SOURCE: GE Spacemaker JVM1631BB005 making noise
Many thanks to e3enigma above! I removed the synch motor under the turntable; all other microwave functions work fine and the grinding noise is gone, hooray! A trip to the appliance parts store tomorrow for a replacement synchronous motor and all should be well. Thanks again!
A
Anonymous
  • Posted on Oct 24, 2008
SOURCE: constant rattling noise during operation
possibly the "stirrer" motor - this is in the top and turns a metal reflecting ring to disperse the microwaves around the oven more evenly. About $70 on GE site for my oven.
Anonymous
  • 331 Answers
  • Posted on Jun 03, 2009
SOURCE: Microwave Upper Stirrer Motor
What up, Roller?
The straight up answer to your question is "Yes, you can continue using the oven without the stirrer motor". Here's the thing, though... the stuff you put in it won't heat evenly. I'm talkin' about big stuff; turkey, ham... stuff like that. And if you've utilized the defrost function in the past, you can forget about that now. But if you use it to heat up a dinner plate or a cup of coffee, you're good to go.
Another thing. You're motor is not the problem, it the coupler that connects to the motor shaft that has given out on you. That's the thing that connects to the motor shaft. You can see it, by lifting the glass outta your MW... see that little plastic drive gear there? It has three spokes on it. That's the gremlin in the machine.
The part number for it is WB06X10144. You can call a local appliance parts place or you can get one online (<---just type in the part number to a search engine).
Simple to replace... pull the old one out and slide the new one into place. See? Easy! Oh yeah, then you have to plug the motor back in, but hey! You already know how to do that! Cool!
Don't forget to rate my solution, OK? Show me some FixYa love, Roller!
SG
Microwace noise coming from top and flashing
dont use the microwave until you retrieve what dropped inside when you removed the port. The grinding is most likely a foreign object that is hitting the moving parts of the microwave and causing sparking. It can catch fire
Microwave makes nioses
I would be concerned but since only a few months old take it back for repair or replacement.
My Dimension4's convection oven often starts to make grinding noises when it preheats.
From the description it is the turnable motor, eventually it will need to be replaced down the road.
1helpful
Rattling, crackling type noise just started and is constant when microwave is running.
A couple of months ago my microwave started making crackling, rattling and grinding sounds everytime i used it and i thought it was going to break down. It turned out one of my children must have spillled or overflowed something with a clear liquid because the micro did not look dirty but there was a crunchy substance under the wheels of the turntable. Once i cleaned this up totally the noises all went away.
6helpful
GE JVM1650 Microwave Making Loud Noise
hello Frank. Sorry to tell you that the magnetron is going bad and making that terrible noise. Since the inside of a microwave, even unplugged has up to 2000 residual and deadly volts of electricity I recommend either calling a pro or replacing the unit.
1helpful
Kenmore 721.80524500 makes a buzzing, grinding noise
Your problem is due to the "magnetron" arcing to the wave guide within the microwave. Picture someone arc-welding stuff together inside the microwave casing, that's essentially what's happening. It is a fire hazard and you should stop using the microwave immediately. As far as I know, there isn't a recall on that particular model (though there was on another similar Kenmore/Whirlpool model) so if it's out of warranty, you're out of luck.
4helpful
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
