FINAL SOLUTION TO FIX THE BELT FROM COMING OFF LT1045 WHILE MOWING! I also had this issue with my LT1045 belt. However, I just figured out how to finally fix / re-engineer my LT1045 Cub Cadet from having issues with the belt coming off of the deck while mowing. Taking it back into a shop for repairs will not work, the belt will just come off again the first time you mow. I am making a YouTube Video to help others like me with this mower issue and will post a link here soon showing how to fix this design flaw. It took me about an hour to fix but I've got it working now with no problems, minimum vibrations and belt is running cool now! I've gone for 2 months with no problems now. Check back soon for the link!! I expect I will have the video tutorial finished within a week!! - Mike If you for some reason you cant
The Cub Cadet mowers are notorious for poorly designed belt-deck configurations. The Idler Pulley Brackets are inadequately supported with springs leading to excessive vibration combined with a misalignment of the pulleys will lead to eventually the belt popping off of the deck and/or being cut by the pulleys themselves. Solution to this problem for the LT1045 and other similar models can be viewed at:http://www.youtube.com/watch?v=Pd4nYovcn...
Deck belt keep comeing off if you try to lower deck below the 3 slot trouble trouble trouble [email protected] 865 - 679-3260
I have this problem with the belt came off of the rear wheel drive
I had this problem, but found the the tension pully under the deck was too loose. I tightened the bolts on the pully and have had no problems since.
