Question about Humminbird Fishfinder, Piranhamax 210 Pt 4068401 Plus
Humminbird LCR 4 ID....I lost power cord and am trying to find out which 2 pins are the ones for the 12vdc power. There are 6 terminals but I know some of those are for temp probe. thanks, rick
Use the top left and right in the star pattern. looking at the 6 pin layout (center pin included), the pins at 10:00 and 2:00 are for the power.
Posted on Jul 10, 2010
  • freelen Fraley
    freelen Fraley Jan 05, 2013
    I contacted Humming bird and they had no data on the LCR4 ID. Which pin is the 12 volt positive connected?
    New Friend:
  • 5 Answers
The 10 o'clock is hot. 12v + 2 o'clock is black ground.
Posted on Aug 02, 2014
Testimonial: "Thank you!"
Nice, Ia friend just gave me one w/o the pwr cord...i`ll try this but anyone know where to get a cord?
Posted on Aug 06, 2010
    New Friend:
I had the same problem. the 4 ID and no power cord. They dont make the 6 prong one anymore. But i hooked it up easily. Only two of the holes need a positive and negative wire to them. Used a small wire connector (14 ga) and 14 ga. wire. The slid on over the two pegs. The outer one is hot. Easy to do and it works fine. Email me at maxijigger@yahoo if you need help. paul
Posted on Aug 17, 2011
  • sharon Sep 18, 2012
    which is positive and negative?
  • bruceharle
    bruceharle Oct 17, 2012
    Does it matter if the 10 or the 2 pin is positive or negative? seems to me it would matter so I am scared to guess at it!
SOURCE:
No power to ignition coil
2004 Suzuki Forenza , so say title.
what engine?, 2.0L or out side usa with 5 engines used.
power to.,.
  1. check fuses yet, that be first. (all electrics that.)
  2. scan it next to see DTC errors related to IGN COIL.????
  3. RTM , the manual is 4 bucks read that yet?
https://suzukipitstopplus.com/Products/1027-2004-forenza-service-manual.aspx
so are you saying there is no spark on all 4 cylinders.
that be first, 1 &4 dead or 2 &3 dead. (coil pack pairs, not with wires scrambled, they most not be connected WRONG)
if only 1 pair fail we have a cure.
if all 4 die, other ,,, see?
tests matter, doing all tests on wasted spark, tells you whats up.
test with 2 spark plugs. new.
shells gounded.
1 and 4
then 2 and 3. pairs.
all 4 fail, or just 1 pair? a key fact. on all wasted spark systems.
if you scan and get DTC shows, cmp dead, ckp dead or
ignitor 1 dead, well, ???? do you>?
coil pack
if pin 2 is 0v, cranking
the fuse EF10 is blown or the pump relay open.
to fix cars like this, you need the book, the schematic,
as seen here.
the ecu fires the hidden coil pack drivers.
if one plug goes open , you lose 2 cylinders
if one HV wire goes open, same.
see?
if one HV wire shorts to ground only THAT cylinder goes dead.
pin 86 is 12vdc cranking
pin 85 , the ECU grounds this pin to send power to the coil pack.
pin 30 is obvious, 12vdc all the time.
Nov 14, 2015 | 2004 Suzuki Forenza
Looking for swivel mounting bracket for a humminbird lcr 4 id
They are on EBAY....
http://www.ebay.com/itm/Humminbird-Mounting-System-Cover-MC-W-740036-1-MC-W-700-798-788-778-/140948056331?pt=LH_DefaultDomain_0&hash=item20d128a90b
Apr 08, 2013 | Humminbird Fishfinder, Piranhamax 210 Pt...
Portable LCR 4000...Need owner's manual...Help?
You can contact our customer service group and see if they still have a manual for this model. There number is 800-633-1468.
Joby @ Humminbird
Jan 14, 2011 | Humminbird Smartcast Rf 35 Dual Display...
Hi, I live in Argentina and I have a kenmore 96093800 Dryer. This Machine has 120/240v and his plug has 4 pins. Two pins are flat, one pin is cilindric, and the fourth pin is en angule. How can I connect...
Are you connecting this Dryer cord to the Dryer or are you looking for a wall plug with this same configuration to plug into. This is a standard double ground configuration and you can buy the wall receptacle at a hardware store. Your house should have 4 wires to this, 2 lines, a neutral, and a ground. As always the recommendation is that you have an electrician install your house receptacle. Your Dryer power cord is something you can install however. The two outside terminals on your dryer 240 volt wiring block are connected to the two outside wires on your power cord. It does not matter which wire goes to which side. Your two inside wires on the power cord are connected like this. One to the middle terminal on your 240 volt dryer terminal block and one is connected to the dryer case itself. Again it does not matter which wire goes to which ground. Make sure all of your connections are tight, as loose terminals eventually burn up. Do Not plug in your dryer power cord until everything is hooked up tight. I actually had a customer plug in his cord and then try to connect the wires to the dryer. The wires arced together and blew the terminals into molten metal which burned this customers hands and face. Do not do and electical repair unless you know what you are doing. On your cord the two straight terminals are line terminals, the round and L shaped terminals are grounds or neutrals. Good Luck, Appliance Specialists
Dec 15, 2009 | Washing Machines
Is there a free downloadable manual for a Humminbird LCR 4000 Fish finder?
type in hummingbird lcr 4000 fish finder manual pdf. it works for anything you want
Nov 04, 2009 | Humminbird Smartcast Rf 35 Dual Display...
Lost power cord
Ebay, or if you arent into auctions you can try directly from pacific digital, they can ship to you. Tell them you didnt have one when you bought it, maybe they will give it to you for free.
Aug 12, 2009 | Pacific Digital (U-30106) CD-RW Burner
Need a user manual for a Humminbird fish finder,
You get a LCR 40-ID, but not a 4.D. Here is the manual for the 40-ID.
Jun 29, 2009 | Humminbird Smartcast Rf 35 Dual Display...
Need the directions to wiring the humminbird fish finder piranha max 210
Wiring should be very straightforward, the connector on the left (looking at the back of the sounder) is the plug for the transducer, the 2 pin plug in the middle is for the power (notch in the plug cord points UP), and the 4 pin connector is for the optional speed and/or temperature sensor. Here is an install manual for your reference:
http://www.humminbird.com/PDF/Piranha1_2_IN.pdf
Mar 15, 2009 | Humminbird Fishfinder, Piranhamax 210 Pt...
Humminbird Fishfinder, Piranhamax 210 Pt 4068401 Plus Logo
3,388 people viewed this question
Top Humminbird Boating Experts
fordexpert
Bill Eager
Mike
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
