Hi we just got all the circuits replaced and now when I select bake for the large oven the broiler comes on along with the top element. in essence it seems to be trying to bake and broil at the same time...first is the top element supposed to come on when I hit bake? I think the answer is yes...but is the broiler pad also supposed to heat up like a blast furnace too...which in time turns off the entire oven when the heat gets too extreme? I don't think it is supposed to...help
SOURCE: Dacor oven will no heat.
The reset button is located near (probably behind) the latch that locks your door during sef clean. The reset is located in the middle a thermostat that looks like a round disc the size of a quater and about 1/4 to a 1/2 inch high with two wires, one on each side, plugged into it. Usually with a long thin screwdriver and the power turned off you can reset it with out having to take anything, or at least very little parts, off.
SOURCE: Dacor ERD30 oven trouble
You must inspect all switch contacts, wire continuity, and connections to be ok.
SOURCE: Dacor ERD30 Epicure dual fuel takes two minutes for gas to flow
Have a look at manual below
http://www.dacor.com/Dacor.Website/WorkArea/showcontent.aspx?id=1297
Or select from here
http://www.retrevo.com/s/Dacor+ERD30?rt=mi&p=http%3A%2F%2Fwww.dacor.com%2FCustomer-Care%2FManuals-And-Specs.aspx%3FTaxonomyId%3D509
SOURCE: Does the Dacor rsd30 have an internal circuit breaker?
Hi!!!you seem to have a problem with your hi- limit switches show here they are resetable in dacor products..just press the top of the hi-limit swith and you will be fine'' they are show here.Good luck
SOURCE: dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
