Motorola Mobility Defy Cell Phone Logo
A
Anonymous Posted on Feb 01, 2014
DEFY C305 REFRIDGIRATOR, FREEZER WORK BUT NOT FRIDGE
Defy side by side fridge freezer. The door is sagging and not sealing.
The bushes in the hinge have worn out. Replace the hinges or if you know someone that can machine nylon or steel, you can get someone to machine you some new bushings.
https://www.google.com/search?q=defy+side+by+side+fridge+freezer+door+door+hinges+replacement
Defy fridge f640 replacing door hinges
Hi, the defrost element of our defy double door fridge is tripping our electricity. Are there any certified defy technicians in the garden route, specifically the George, Sedgefield area?
Contractor's Assistant: What's https://waltonbd.com/refrigerator-freezer/freezer and model of your fridge? How old is it?
Defy double door model F640 and it is about 15 years old
Contractor's Assistant: How long has this been going on with your refrigerator? What have you tried so far?
For about a month. Just before Christmas. We have had an appliance technician here and he said it's probably 99% the defrost element. He checked everything else, the plug the gas etc. Those were all in order.
1helpful
Defy fridge freezer G91641N panel , lights, keep flashing
When the panel lights on your Defy fridge freezer are flashing, it usually indicates an error or a specific condition that needs attention. Here are a few steps you can try to troubleshoot the issue:
  1. Power Reset: Start by performing a power reset to see if it resolves the flashing lights issue. Turn off the fridge freezer at the main power supply or unplug it from the electrical outlet. Leave it unplugged for a few minutes, and then plug it back in or switch on the main power supply. Check if the lights continue to flash.
  2. Check Error Codes: Consult the user manual or documentation for your Defy fridge freezer to identify the meaning of the flashing lights or any error codes displayed on the panel. The manual will provide specific information on what each flashing light or error code signifies and any recommended actions to resolve the issue.
  3. Temperature Settings: Ensure that the temperature settings on the fridge and freezer compartments are set correctly. Incorrect temperature settings can sometimes trigger error codes or unusual behavior. Adjust the settings to the recommended levels and observe if the flashing lights persist.
  4. Contact Customer Support: If the flashing lights persist or you are unable to identify the issue using the manual, it's recommended to contact the Defy customer support or an authorized service center. They can provide further guidance and assistance in diagnosing and resolving the problem.
2answers
Defy fridge only works on the freezer side. The fridge side is warm! What could be the problem.
The freezer provides the cold air for the fridge via a vent at the back of the fridge. If you have a fridge freezer where the freezer is on top of the fridge, sometimes the vent can get blocked by ice. You would have to remove the food from the freezer and remove the back panel to look. Ice can be removed with a hair dryer or a heat gun.
The other possibility is that the recirculation fan in the fridge has stopped spinning.
Or it needs more gas although this is unlikely.
Hello i have a defy eco model no g91641n its giving me a error status indicator . the fridge side is working but the deep freezer is not working please help
Hi i have a defy G91641n it cools but the temperature adjuster dont work it shows funny figures and light is off amd doesnt beep but cools the fridge and freezer
DEFY C305 combi top fridge bottom freezer FAULT:freezer operates ok, but fridge is running hot.
do you mean that your fridge is not cooling and freezer just freezes up ?
Defy fridge f640 wiring diagram faulty compressor or thermostat
Hi my name is jp. Got a defy f640 the freezer not working. Trips power. Wires been removed at back of the compressor. Need to know where the wires need to go
Freezer work great but the refridgirator doesn't get cold.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
