Reebok edge 2.2 treadmill stopped suddenly then blew fuse
1) Inspection if the fuse is the correct Amper and Voltage: example: you can not connect any FUSE less if they use 10Amp, not use 5 amp, or 15amp. That situation is delicated.
2) clean contact fuse, and retight the clips of the fuse, and tight the wire to the clip of the fuses.
3) The motor is Short or ground: Test with Some DVOM, maybe the winding is short,and need maintenance: brushes, grease, and clean, bearing. or the winding is faulty.You can go to some Shop for repair electrical motor.
sincerely.
E.CUADRA
