Lenovo idea flexpad 20
1. Check for a bad battery. This is the most common problem for mobile devices like tablets, laptops and the like. Since the battery must be fully functional (at OEM specified outputs for volatage and current) for the device to operate (manuf. designed it that way to protect the circuits years ago), it is the most likley culprit. (FYI: I have two Lenovo laptops - one under the old IBM Thinkpad label and one newer Chinese Lenovo).
* Replace the battery with a new OEM replacement as I do not recommend after-market generics or refurbished)
2. Try a different power supply. Check the OUTPUT requirements on your existing power adapter (usually 5v) and locate a another adapter to see if it is the AC adapter. The only real issue you need to worry about is the OUTPUT voltage must match the original adapter to avoid damage. The current does not matter since the device determines how much current in mAH it requires so just concern yourself with the right OUTPUT VOLTAGE and the jack plug makes a proper fit. If a spare adapter is not available (Radio Shack sells a variable voltage adapter with a variety of interface plugs and they work very well for these issues) then try using the Lenovo adapter on another device. (I am assuming you do not have electronics tools or test bench and need to troubleshoot the old school way)
* Replace the dead adapter ensuring that the VOLTs are the same on OUTPUT as the original and the interface plugjack is the same size.
If, after doing the above two simple steps, consider that the MB (mainboard - motherboard) power supply is toast and the laptop is good for recycling only
