I replaced the speed sensor and that did not correct the problem. Need to find a wiring diagram so I can search for an electrical issue.
Http://www.bbbind.com/technical.html
Free wiring diagrams and TSB's, every make and model. Click on TSB's and wiring diagrams, next page-agree to end user license agreement, then next page click on Wiring Diagrams and enter car information.
Dealer service or auto parts store..
SOURCE: diagram for 1988 pontiac 6000 steering columb
What is it you are looking for.... easiest way to get one is to either buy it at autozone or canadian tire if you live in canada. or the public library.... search for haynes or chilton.
Robert
SOURCE: Location of the speed sensor for a 1994 Pontiac Grand Am 3.1.
Where the spedometer cable goes into your transmission, that is where it's located.
SOURCE: need a wiring diagram for distributor for a 1988 pontiac fiero gt with a 2.8 v6
There are two plugs which are plugged into the distributor one is a two wire and one is a four wire. the two wire has a pink wire on terminal A and a white wire on terminal B these two wires go to the remote coil black plug The four wire has a black wire with a red trace on terminal A A tan with black trace on terminal B A purple with white trace on terminal C A white wire on terminal D
SOURCE: 88 pontiac 6000 shudders and stalls after approx. 30 min. driving
What was replaced in the tune up? Usually the coil paks cause these types of issues. Also fuel filter or fuel pump will allow enough fuel to start and sputter like you describe.
The final fix was to replace the ECU.
