I added [email protected] yesterday. I did not realize that my [email protected] would disappear. Can Iget it back?
SOURCE: I sent money to the wrong email address. I have
to be honest i have no idea as i will not send cash via internet but prefer to use a cheque by post or straight into a bank account ,only suggestion i can make is to pay a visit with a pick axe handle .This always works for me when non payers abound ,make sure no visitors and cut any phone cables also use a high powered CB radio boots of around 500watts and key up with a whistle noise and this will blank out mobile phone signals with a 100ft range of so .another less violent way is to sit them in a chair with wooden floorboards and then some nails and a big hammer then bang a nail onto the floor next to their feet .the disputed amount soon appears from nowhere .
SOURCE: Created a new gmail address and cannot access it. It says I have the wrong address or password???
Hi Cher,
Most likely, you're using the wrong password. Most times this is because you have accidentally enabled CAPS LOCK when you were creating the account, or you were using the numeric pad whilst it was disabled (hence you didn't type any numbers in the password, although you thought you were). Try to login and use the password you know but enable CAPS LOCK or disable NumLock before you type it (i.e. try replicating what your keyboard status was)
If unsuccessful, either give up the account and create a new one or try calling Google support - but keep in mind they may suspect you're trying to hack into someone's account, unless you know all the details AND you're using 2 way authentication (i.e. you have added a mobile number where you can receive an SMS with a code)
SOURCE: how do i get my old email back
Go to Gmail Webmail page [gmail.com]. Logout of your current gmail account if signed in. On the login page select add account or login another account, Enter your old email address and then select "need help". This where your can recover your password if old email address is correct. It can also help with account name once you provide the needed info. This should work provide the account was not deleted.
Testimonial: "LOOK I HAVE DONE THIS. THEY KEEP ON SENDING THE NEEDED INFORMATION TO AN ALD AOL ADDRESS WHICH IS NOW DEAD WITH NO HOPE OF REVIVAL. I HAVE REQUESTED THAT THEY CHANGE THIS ADDRESS TO A NEW YAHOO ADDRESS. AND THEY DON'T DO IT"
SOURCE: how do i change my primary gmail address
From gmail and your computer ? Or thru your phone? They are different procedures.
