Hi
My saeco vienna digital is about 6 years old and was working fine until 2 days ago when it started giving me the message brew group blocked. I followed the manual and it says to drain it and turn off the steam but even that is not working. Can you kindly help? Thanks Frank
Hi There is a test mode for the Digital and we can see if you have a bad power board. Turn the machine off in back. Push and hold the small coffee button and the menu button (top left) at the same time and while you are holding the buttons turn the machine on. Release the buttons and you should have numbers in the display. If you can push the bottom left button and the machine makes a sound like the motor is moving, turn it off and then back on. If you don't get the message now you should really clean and lube your brew unit.
I did not get a sound on the left button and the second button. but did get a grinding sound (like the grinder was running) on the third button and snap sound on the fourth button. The brew unit has been cleaned thoroughly but not lubricated. Any further suggestions? Are the numbers in the display error codes? If so, is there a guide for the codes?
I get 3 56 8
130
when i push the left bottom, motor not hear, when swith off and on selftest, and nothing happend.
Sometimes it grind coffee, but than it stop and say brewunit block,
please help
Yes i am slightly familiar with the maintenance menu.Do you know what the numbers in the display mean? I did that and the motor is turning but very slowly. How do i know from the numbers that the board need s to be replaced?
