Sony VAIO VGN-N130G/W Notebook Logo
f
farzad_ghara Posted on Feb 01, 2014
Keyboard driver for vgn-fw490jcb windows 7 64-bit
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Need driver for sony vaio VGN-TZ27GN built in web...
There probably is not a driver specifically for Windows 7.
Usually you will have to use the one for Windows Vista.
Windows 7 is only a glorified version of Vista anyway.
Go here:Drivers
Select the Downloads tab, then select the operating system.
If you have 32 bit Win 7 then select the 32 bit Vista.
If you have home premium then select the same for Vista.
In the next drop down menu select Original Driver.
There is one for Vista called camera module driver
Dear sir, i owe a sony vaio VGN-CR31S/L and want to completely uninstall windows vista 32 bit and install windows 64bit. But the problem is im looking for all the drivers and still didnt find them. i...
Hi.
You may download all the Drivers and Applications for the Windows 7 64-bit Operating System from the below link:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR240E&SelectOS=6
Please select the Operating System as "Windows 7 64-bit Operating System" and then download the required Drivers or Applications.
Once you have installed the Drivers and Applications, please restart the Computer for the settings to take effect.
Hope this helps.
Please feel free to contact for further assistance.
Thank you.
Suresh
2helpful
2answers
My sony vaio vgn-cr220E was uprraded from vista to windows 7..why does the biult in motion eye camera doesnt work..
You need the Win7 camera driver, check sony support at:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220E&SelectOS=44
just enter your Win7 operating system (there are 9 versions of Win7), and select the downloads (2)
for your computer camera driver.
Versions of microsoft Win7 - determine which yours is by (these instructions are for WinXP);
START > Control Panel > System > General (tab)
Windows 7 Home Basic 32-bit
Windows 7 Home Basic 64-bit
Windows 7 Home Premium 32-bit
Windows 7 Home Premium 64-bit
Windows 7 Professional 32-bit
Windows 7 Professional 64-bit
Windows 7 Starter 32-bit
Windows 7 Ultimate 32-bit
Windows 7 Ultimate 64-bit
I have a sony vaio vgn-sz491n. i have loaded windows 7 professional, 64bit onto it. in the device manager, it shows that a driver for a mass storage controller is missing. where can i find this...
Most likely missing a driver for SD/MC card reader
The problem is that Sony doesnt offer drivers for 64-bit windows so the other 32-bit drivers will not be compatible.
You have the options to install the windows versions supported by sony from esupport.sony.com (Vista or XP)
Or try installing windows 7 32-bit and installing the missing drivers from esupport (Vista section) as usually they are compatible.
If the driver is still missing you will need to update the driver from device manager (previously installed from esupport) and then select to browse or select a location, which will be %temp% or what is the same the temp folder for your account C\users\your_user_name\appdata\temp. This folder is usually hidden but it will work if you just type %temp%
3helpful
FROM WHERE CAN I GET WIN.7 DRIVERS FOR SONY VAIO VGN-N250E
As if now windows 7 drivers are not available but you dont have to worry because Basic system functionality should be automatically enabled with the drivers included within the Windows 7 operating system.
However, if one of the drivers that came with the operating system does not work with your system, you can try installing the Windows Vista version of the driver provided by Sony for your model. Many of the Windows Vista drivers are compatible with Windows 7 based on current testing. Make sure you choose the bit version (32-bit or 64-bit) that matches your version of Windows 7.
For for driver download visit this website :
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNN250E
For information about windows 7 upgrade visit this website :
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=24
Sony vaio VGN-FS640/W Keyboard Error
Check the key isn't stuck down first, if not you may have a corupt driver, go to my computer< right click>properties>hardware tab>device manager and then in the next window, go down to keyboards, click on the'+' sign and right click on the line and select uninstall. Restart you pc and the keyboard will be re installed automatically and the driver loaded. Try again.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
