UNDER LIGHT ENGINE LOADING THE RPM SURGES UP AND DOWN BY ABOUT 200 RPM. ACCELERATOR VERY TOUCHY. SEE http://townhall-talk.edmunds.com/WebX?14@@.f1074ce/0#0
problem throttle body or accelerator position sensor
there will be codes but it will need somebody experienced with the right scanner protocol to read them
You could have a bad or contaminated Mass Air Flow (MAF) sensor. You can get a used one online for less then 100. You can also purchase a can of MAF sensor cleaner at a local auto supplies store and clean it. It located right at the air filter housing.
yes it could be. have fuel pump pressure tested, fuel pump pressure should be. (key on engine off) 1999 to 2000--with egr--41 to 47 psi without egr--52 to 58 psi,
this sounds similar to a problem i had.
as the rpm went over 2000 the engine would stop for a split second and then kick back in.
after a few days looking my garage finally found the problem was a faulty air mass meter.
this cost me £200 in total to be repaired.
