SOURCE: dropped phone won't work
You've ruined your blackberry to say the least. I used to have the blackberry pearl, your going to have to take it to a technician because you probably damaged some internal hardware. Your best bet is to take it to a technician to have it repaired, if they can even repair it, or buy a used blackberry from your cell phone company. Kinda sucks, but that is how they make there money- and get a touch case if you choose to get a new one. Swissgear is very very durable! Sorry your having a problem! Wish you the best of luck.
SOURCE: blackberry pearl
Try holding these keys simultaneoulsy.
ALT+RIGHT SHIFT(CAP)+DELETE Until you get a blank screen then power on.
Failing that power off, remove your battery for 30 seconds and then power on.
SOURCE: blackberry pearl 8130. screen wont come on.
To help you with this problem, I want you to know that when a cellphone
got fell, the main problem will be make is lost in display,you will not
see anything but you can hear something like message tone and start-up
tone, you can also receive calls. Don't be worry with that kind of
problem. To tell you whats happening inside your phone is your LCD of
display connection is only misaligned. Get it to the nearest cellphone
repair center to get your cellphone to be open by a technician and
probably they will do dismantling your phone and fix the problem. Hope
this could help. Don't forget to say thanks..:-)
SOURCE: i cant turn on my blackberry pearl 8110. Red light just flashes
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
Still if it is not working kindly remove the Battery of the Handheld and try in some other Handheld.
If the Battery is working fine in the other Handheld then there might be some problem with your Handheld, you need to walk into the service center.
If the Battery is not working in the other Handheld then there might be aproblem in the USB cable for these you need to walk into the service center
