After every wash a little water leaks from the drain pump
SOURCE: Problem : Water leaking out from under washing machine
NOTE. PLEASE UN-PLUG THE UNIT FROM THE ELECTRICITY SUPPLY BEFORE ATTEMPTING THE FOLLOWING JUST TO BE SAFE:-
Problem may be due to a blocked dispenser hole. Completely remove the dispenser unit and check for blockages in the hole where the water goes in. If you cant see anything immediate, take the top off. (Remove the 2 self tapping screws on the back holding the top on). Looking at the unit from the front. look inside where you took the top off and locate the rubber hose that connects the dispenser unit to the drum (it's a tight space, but if you look inside , front left you will see where the hose connects to the drum). Remove the hose and check for blockages. (The hose just pushes into the drum). Let me know. I had a similar problem and found that somebody had shoved a sock and pair of knickers down the water dispenser hole. This was also causing the machine to make a loud noise when spinning. Have you also checked the filter in the bottom right hand corner of the unit ? You have to remove the kick panel to get access to it.
SOURCE: My washing machine is a
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
SOURCE: wtr902 model 9kg direct drive
is it leaking down the front dead center clean inner door glass any lint on glass or even 1 animal hair can creat a leak on door seal
In all occasions it is important that your observation
is most important and so is vital to the identification /rectification and
solution. If you have noticed that water has leaked then as the drain hose
pump/valve and fittings are located on the underside of the machine it is
important that you look for possible leaks here. In some cases the drain hose
would be clogged at the drain end to outlet of the house and so there will be
back flushing resulting in overflow to the outside. Also the drain pump/valve
can be clogged or the drain hose clamps can be loose on the grip which can all
cause the leak to occur. Removing and cleaning the drain pump/valve, tightening
of the hose is also very important. Also water can leak if there are gaps on
the front door gaskets and must be checked but this will happen only during the
cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing
Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
It is so common that the drain leaks in many ways and
is the most problematic fault in a washing machine. In all occasions it is
important that your observation is most important and so is vital to the
identification /rectification and solution. If you have noticed that water has
leaked then as the drain hose pump/valve and fittings are located on the
underside of the machine it is important that you look for possible leaks here.
In some cases the drain hose would be clogged at the drain end to outlet of the
house and so there will be back flushing resulting in overflow to the outside.
Also the drain pump/valve can be clogged or the drain hose clamps can be loose
on the grip which can all cause the leak to occur. Removing and cleaning the
drain pump/valve, tightening of the hose is also very important. Also water can
leak if there are gaps on the front door gaskets and must be checked but this
will happen only during the cycle and not on the drain cycle end.
Replacing
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
when washer start to spin the water out it leak, not every time but it leaks
We were told that we are using too much powder by the Malber people. We switched to a liquid detergent at their suggestion (front-loading, high-efficiency liquid). Same problem. I think this machine just has a design flaw.
Just started leaking a bit in front of machine no action taken to repair yet. Wondering what the cause is before procededing. thats why I'm here.
how do you remove the pump
This washer has never cleaned very well. Often I have to do three full cycles to get a clean rinse. It's a nightmare. I was hoping it has a clogged lint catcher, that might be the reason it is never cleaned or rinced well. Now it leaks. I wish I has read more evaluations before I bought this les-than-quality washer.
