SOURCE: How do I set the 12 or 24 hrs setting on my Casio DW 9052 casio?
when you are setting the time just hit the (g) or light button and it will switch it to 2400 time.
SOURCE: For Casio F-91W how do I replace battery? I see 4
Most of these resin-case F-series Casio sport watches use a fairly large lithium coin cell battery. Once the four screws holding the watch back are removed, you should be able to just pop off the stainless steel spring clip that holds the cell in place and pull it out, without having to remove any more screws. Be careful when replacing the clip, because it is asymmetrical and goes in only one way. Also be careful not to lose the tiny spring contact that connects the watch movement to the piezoelectric sound element glued to the watch back. If you lose the spring, the watch will still run, but the alarm won't sound anymore.
SOURCE: casio databank 150...how to change from am to pm
Write down the four-digit module number from the watch back, and go to this link for full info in PDF format:
http://world.casio.com/wat/download/en/manual/
Good luck, Bill
SOURCE: lost manual, need to set
Hi,here is the user manual.. http://world.casio.com/wat/download/en/manual/
soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
Use this page to download a copy of CASIO watch manuals in
PDF format.
To download a PDF file, enter the four-digit (or three-digit)
module number marked on the back cover of your watch.
SOURCE: how can you make a "Casio f-91w" watch not beep
Push the lower left button. The alarm time is showing.
Press the lower right button and it will cycle the hourly beep and alarm on/off.
Press the lower left button to exit when the setting are what you want.
