Nokia 6670 Cellular Phone Logo
A
Anonymous Posted on Feb 01, 2014
Internet settings - Nokia 6670 Cellular Phone
Hy, I am not able to access Internet on changhong though everything is fitted properly. My internet is also working cool. So dere is a problem with the tv. How should I overcome it?
Reset Internet Explorer settings
You can reset Internet Explorer settings to what they were when Internet Explorer was first installed on your PC. This can be useful for troubleshooting problems that may be caused by settings changed after installation. Note that resetting Internet Explorer isn't reversible, and all previous settings are lost after reset.
  1. Close all Internet Explorer windows. Select the Tools button, and then select Internet options.
  2. Select the Advanced tab, and then select Reset.
  3. In the Reset Internet Explorer Settings dialog box, select Reset.
  4. When Internet Explorer finishes applying default settings, select Close, and then select OK. Restart your PC to apply changes.
tip
Wifi Guide For C3 also other phones
<span><b><u> <span><b><u><img src="vhin100889_25.jpg" /><br /></u></b></span>* How to deal with WLAN (WiFi) *</u></b></span> <span><b><u><br /></u></b></span> <span><b>Setting 1:- Go to Menu &gt; Settings &gt; Connectitvity &gt; WLAN &gt; Internet connection &gt; Ask first<br /><br />- Goto Menu &gt; Settings &gt; Configuration &gt; Default config. settings &gt; myGlobe (or Smart)<br /><br />- Goto Menu &gt; Settings &gt; Configuration &gt; Preffered access point &gt; myGlobe Internet (or Smart Internet)<br /><br />- Goto Menu &gt; Internet &gt; Web settings &gt; Configuration settings &gt; Configuration &gt; myGlobe Internet (or Smart Internet)<br /><br />- Goto Menu &gt; Internet &gt; Web settings &gt; Configuration settings &gt; Account &gt; myGlobe Internet (or Smart Internet)<br /><br />- Select your preferred scanned network, then Connect.<br /><br />- You will notice a WiFi signal logo ..oo)))) on the top screen indicating you're connected.<br /><br />- Go to MENU &gt; Internet &gt; Go to address <i>(and enter the website you want)</i><br /><br />- Done. Enjoy browsing via WiFi.</b><b><br />Setting 2:- Go to Menu &gt; Settings &gt; Configuration &gt; Personal Settings &gt; Add &gt; Access point (leave others as is) &gt; press back &gt; Option &gt; Activate- Goto Menu &gt; Settings &gt; Configuration &gt; Preferred access point &gt; My access point- Go to Menu &gt; Settings &gt; Connectitvity &gt; WLAN &gt; Internet connection &gt; Ask first<br /><br />- Go to Menu &gt; Settings &gt; Connectitvity &gt; WLAN &gt; Available WLANs<br /><br />- Select your preffered connection, then connect.</b><b><br />Note:- Update your phone to the latest firmware, preferrably version 7.20 or higher. Firmware upgrade might solve Web browser bugs and WiFi issues.<br /><br />- Check your WLAN server, you might have a weak WiFi signal.</b></span> <span><b><u><br /></u></b></span>
on Jul 12, 2011 • Cell Phones
Closed internet explorer at runing
When you reset Internet Explorer to its default settings, all changes that were made to Internet Explorer after it was installed are removed. However, this action does not delete your favorites or feeds. To reset Internet Explorer to its default settings, follow these steps:
To reset Internet Explorer automatically, follow these steps:
  1. Click this button:
    fixitbutton1.jpgReset Internet Explorer settings
    Microsoft Fix it 50195
  2. In the File Download dialog box, click Run, and then follow the steps in the wizard.
  3. In the Reset Internet Explorer Settings dialog box, click Reset.
    Click to select the Delete personal settings check box if you would also like to remove browsing history, search providers, Accelerators, home pages, Tracking Protection, and ActiveX Filtering data.
  4. When Internet Explorer finishes applying default settings, click Close, and then click Close again.
  5. Close Internet Explorer, and then restart it.
Let me reset Internet Explorer myself
To use the Reset Internet Explorer Settings feature from Control Panel, follow these steps:
  1. Close all Internet Explorer and Windows Explorer windows.
  2. Click Start Collapse this imageExpand this image vistastartbutton.jpg , and then click Control Panel.
  3. In Control Panel, open Internet Options.
  4. Click the Advanced tab, and then click Reset.
  5. In the Reset Internet Explorer Settings dialog box, click Reset.
  6. When Internet Explorer finishes restoring the default settings, click Close, and then click OK two times.
  7. Close Internet Explorer, and then reopen it. The changes take effect the next time that you open Internet Explore
1helpful
3answers
Internet settings
You should contact to customer helpline that operator are you using they will send internet setting on your mobile number .
Message: HTML Parsing Error: Unable to modify the parent container element before the child element is closed (KB927917)
From MS site:
Method 1: Follow the provided article.
http://support.microsoft.com/kb/308260/
Method 2: Reset internet explorer and check, whether the issue persists. Follow the steps mentioned in the article given below.
http://windows.microsoft.com/en-US/windows-vista/Reset-Internet-Explorer-7-settings
Note: The Reset Internet Explorer Settings feature might reset security settings or privacy settings that you added to the list of Trusted Sites. The Reset Internet Explorer Settings feature might also reset parental control settings. We recommend that you note these sites before you use the Reset Internet Explorer Settings feature.
3helpful
2answers
Internet explorer finds a problem with the web ppage and wont open the game the rooms are there but wont let me into them i have updated my flash player and adobe reader etc
Try This:
How to Reset Internet Explorer settings
By resetting Internet Explorer settings, you return it to the state it was in when it was first installed on your computer. This is useful for troubleshooting problems that might be caused by settings that were changed after installation. When you restore Internet Explorer's default settings, some webpages that rely on previously stored cookies, form data, passwords, or previously installed browser add-ons might not work correctly. Resetting Internet Explorer to its default settings does not delete your favourites, feeds, and a few other personalized settings. See the table below for a complete list of all settings and information about whether they are reset or maintained.
Resetting Internet Explorer's settings is not reversible. After a reset, all previous settings are lost and cannot be recovered. Rather than resetting everything, you might want to reset specific settings or delete your webpage history.
To reset Internet Explorer settings use the following procedure
You need to make sure you have Closed any Internet Explorer or Windows Explorer windows that are currently open.
Open Internet Explorer and Click the Tools button, and then click Internet Options.
1.png Click the Advanced tab, and then click Reset.
2.png In the Reset Internet Explorer Settings dialog box, click Reset.
3.png When Internet Explorer finishes restoring the settings, click Close, and then click OK.Close Internet Explorer.
Your changes will take effect the next time you open Internet Explorer.
1helpful
Hi, Having problems connecting the PS3 to the Internet?
There are two ways to connect to the internet there is Wireless or Wired connection here is how to do both:WIRELESS (WIFI):
Step 1: Turn on the PS3
Step 2: Once on main menu go to settings and under settings select "Network Settings"
Step 3: Select "Internet Connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step4: Select "Easy" on types of installation.
Step 5: Select "Wireless" to choose what kind of Internet connection you want.
Step 6: Select "Scan" to search for internet access points.
Step 7: Select your home connection when the screen comes up with all the found access points. If your home internet access point requires a password enter the password when prompted and save your settings.
Step 8: Test the connection to check if you configured your settings right if successful you are good to go. If not go back and check your connection settings for your home internet access point. You are now connected to the internet!
HARDLINE (Wired): Must connect ethernet cable to PS3 before turning it on!
Goes like this: Arrows are the cable (===>)
Internet Line ===>Router ===>PS3
Step 3: Go to "Internet Connection" and select it to Enable it.
Step 4: Select "Internet Connection Settings"
Step 5: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step 6: Select "Easy" on types of installation.
Step 7: PS3 will automatically check your connection network setup and set the settings for you.
Step 8: The settings will appear and press x to save the settings.
Step 9: Test your connection if it was successful you will see succeeded nest to "Obtain IPAddress" and "Internet Connection" you are now connected to the internet!
2helpful
How to connect PS3 to the internet?
Step 3: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step 5: Select "Wireless" to choose what kind of internet connection you want.
Step 7: Select your home connection when the screen comes up with all the found access points. If your home Internet access point requires a password enter the password when prompted and saveyour settings.
1helpful
No puedo conectar mi ps3
WIRELESS (WIFI):
6helpful
2answers
My Sony Ericsson W395 asks for the Java Internet Settings when I try to access aplications. I am able to browse the internet with the phone though. Where do I find the Java settings as the service provider...
I have w395 and i can connect to the net with opera mini...
The only thing to do is manually set the Java Internet setting, (press option in Opera mini then setting... you should create one internet profiles...
Fill it with the same setting you used in the Internet setting...
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
