Samsung S730 always reads card locked!
SOURCE: samsung digimax4010 memorycard locked cant take pictures
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
SOURCE: card error samsung s730
I own a Samsung S730, i downloaded all the drivers on Vista Home, I tried formatting the SD Card but it says CARD LOCKED, and it isnt. Any solutions
SOURCE: Camera or cell problem??
A tv remote needs an extremely low amount of power. In fact, many people save the batteries from other devices when they stop working and place them in their remotes. Questions to ask yourself...are the batteries old?....have they been recharged many, many times?...have I accidentally allowed them to completely discharge?...have I cleaned the battery contacts in the camera and the batteries themselves with a cotton swab lightly dampened with rubbing alcohol?
SOURCE: S730 lens in extended position camera not working
The problem you describe is frequently battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing into the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
SOURCE: it is showing card locked
"card locked" usually means the slide switch on the side of the card is in the wrong position.
