SOURCE: Find the antilog on the TI-83 Plus for finding pH in chemistry problems
I reccently had the same problem, but I have a Ti-84 Plus,and I am disgusted by how poorly this matter is covered by Texas Intruments. Esp. since the solution is rather simple.
The antilog key is [2nd] [log] or the 10^x. On your screen it should apear as 10^( and then you just input the value that you want to find the antilog of.
When used to solve pH problems remember to input the pH value as a negative number, since pH= -log[H+] then [H+]= antilog(-pH).
Hope that helped))))) ^^
SOURCE: antilog in chemistry problem
pH is minus (log to base 10) of the hydrogen ion activity of an aqueous solution, or (log to base 10) of (1/hydrogen ion activity)
To get the inverse log, i.e the hydrogen ion activity corresponding to a specified pH, simply enter the pH value and press
2nd
LOG
1/x
Answer 0.001
SOURCE: Find the antilog on the TI-84 Plus for finding pH in chemistry problems
I'm not specifically familiar with the TI83 or TI84 but I've used a lot of TI calculators in my time, so I'll give it a try. If your trying to find the antilog of a number in base 10 enter the number and hit the (10 to the X) button. If you're trying to find the antilog of a number in in base e (natural log), enter the number and hit the (e to the X) button.
SOURCE: simplifying fractions on the TI-30XA
Two ways:
1) hit the equal sign
2) hit 2nd and [d/c] (you can do this multiple times to see it as the most reduced improper fraction or as a mixed fraction)
SOURCE: How to use antilog?
As you well know the pH is the negative of the log in base 10 of the H+/H3O+ ion concentration. If we use [H+] to represent that concentration, then pH=-log[H+].
To obtain the [H+] you need to calculate the antilog. You write the definition in the form log[H+] =-pH and then calculate 10 to the power of each member. The equality remains valid as both members are treated similarly. Thus
10^( log[H+] ) = 10^(-pH)
Since raising 10 to a power is the inverse function of taking the log in base 10, 10^(log(x))=log(10^(x)) = x (they are inverse of one another), you are left with
[H+]=10^(-pH)
Your calculator has a function [10 to x] accessed by pressing the [2nd] function key. To use it you must enter the negative value of the pH, press the [2nd] function key then the [10 to x], then the = key to get the result (concentration)
Exemple: let the pH=5.5, what is the H+ concentration?
With [(-)] being the change sign key, then
[H+]:[ (-) ] 5.5 [2nd][10 to x] [=]
The result is 0.000003162 or 3.16 x 10^(-6)
Hope it helps.
If you use your imagination you can come up with some really inventive ideas, using plants, bookcases, curtains or panel dividers to create some privacy in your home without having to buy a room divider.
