SOURCE: Nikon D40 I bought a set
Macro lenses are mounted to your camera body in place of the lens you currently have mounted on the camera. If you bought the camera with the lens already mounted you may not have realized that the camera and lens are 2 separate objects. To remove your lens see page 8 in your user manual for instructions and an illustration. If you don't have your user manual handy, you can download a PDF file from NikonUSA Here.
If what you bought are macro rings, they go on the camera, then your regular lens mounts onto the ring. You can use one or more of the rings between the lens and camera to produce different macro settings.
If what you bought are macro filters, they screw on to the front of your lens. If you have a UV filter on your lens you need to remove that before you attach another filter.
SOURCE: Fitting a Sigma Lenset to Nikon D40
You have to make sure you bought the sigma lens with a NIKON mount. Sigma makes a Sigma mount as well as a Canon mount, of course neither of those mounts will work with your camera. Also you must also make sure your lens is the Sigma 70-300 HSM (/Hyper Sonic Motor) or it will not AF on the D40. I just bought this lens from Abes of Maine and I love it on my D40.
SOURCE: Nikon D40 is taking Dark Pictures. Flash is
kindly see the aparture and speed of xpouser and the iso also if the iso is 100 change the iso to 400 or 800 or u can select he programme option for the best xpousers
