Bottons on console not working machine turns on belts runs incline works
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
SOURCE: I have a NordicTrack A2250, about 2 years old.
Will the treadmill work when the chip is not plugged in, or does it just beep every time you select a button? If so, your problem is easy to solve. The board that supports the two adjacent up and down buttons has slipped. To fix, you'll need to remove the panel and remove the 3-inch retaining bar which is held in my two screws. Realign the board so the buttons are free to move in the available slots. Good luck.
SOURCE: My nordictrack a2250 turns on, the incline works,
the motor controller is bad and needs replaced
SOURCE: NordicTrack T5.3 belt stopped working. It's only 1
HI, its seems like the belt on the motor has either slipped off, or you just need to tighten it. best way to find out is to take off the front pannel showing the motor. then stand on the treadmill. start it and you will see the problem.
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
sincerely. Please keep me in touch.
