Test the outlet that it's plugged into, to make sure it's still functioning properly. There may be a loose connection at the receptacle or the circuit breaker in your home's circuit breaker panel, for that receptacle may have been tripped. If it is, before resetting it, make sure the air purifier is not plugged in to it. Then plug the unit in and turn it ON. If the circuit breaker trips again, there's a wiring short in the air purifier. Contact Sharper Image for possible repair or replacement.
Replacement grids have been posted to ebay. You can replace the complete unit for $45 on ebay so that would probably be a better solution. The last grid I purchased on ebay for similar was around $20.
If you're
talking about those little plastic tabs at the bottom, they aren't important.
Their job is to wipe the ionizing wires when you take the grid out or
replace it.
You
might be able to pick up spare parts if you scour eBay long enough.
Sharper Image has recalled the units after Consumer Reports reported that they didn't work. They went to court Sharper Image couldn't prove that they did work, was ordered to pay all the legal bills, and filed for Chapter 11.
Consumer Products Safety Commission is going to issue a report at the end of the year on all ionizers. Their decision will effect sales of all ionizers in the U.S. With EPA data indicating that not only do they work but there harmful to use, it's beginning to look like the product is going to vanish.
had the same problem with ionic pro ca500. i took the unit apart and found a fuse that was blown and it works now. sorry but i don't know if there is any repair shops.
http://www.allergybegone.com/ionbreezquad1.html There is a manual for your purifier at this website. It is in pdf form, free to download. look for the sentence on the page. it will take you to the download.
