Amana side by side
model number ARS2364AC
Check the back (interior) lower half of the freezer wall. If you see a frost build up, you either have an issue with your defrost cicuit (timer, heater, thermostat) or the evaporator (freezer) fan is not running. If there is not a frost build up on the back wall you either have a sealed system (weak compressor, leak or restriction) problem....or the condensor fan motor is not working. This would cause the compressor to overheat and shut down until cooled, and prevent the deep freeze.
