I was told that if you have an 11 8 prop you can go to a 12 6 prop and it would be the same
Depends on whether or not the engine your running can handle the extra spin load of a 12/6. Here's a chart of interchangeable props based on engines and their capabilities and not on thrust characteistics. The longer blades cause more centrifugal force and drag, and will result in slower top engine speeds.
http://www.wcrcskyhawks.com/rcinformation/Prop_Charts.pdf
They're similar but you have to be up to at least a .70 to run them and you didn't include any engine info.
For car running hot and overheating issues, I suggest to you go through this help links.
Click this link below and go through the troubleshooting procedure to take care of the problems: ----
Car runs hot?
http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?
http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
overheating?
http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
