My casio protrek 2500t watch is in power saving mode but even after keeping in dark for hours between 10pm and 6 am the display does not go off.Please help.
I own the same PRW-2500-1A (all black).Check if under the hours reading, PS appears.If yes,power saving function is activated.
Normally, Power Saving Function is enabled automatically (if activated) if the watch stays in complete dark for sometime.If after a couple of hours in the dark the watch comes suddenly under bright light,the display goes on immediately.Hour interval (10pm-6am) has nothing to do with Power Saver.
Try the following:
a)Deactivate and reactivate (or vice versa) the PS.
b)Leave the watch in the dark for a couple of hours .Then,still in the dark,try,using a very low power light (just that you can,barely read) to check if display is blank.If not you may have a problem with the light sensor found at the bottom of the display.Will be a very rare case but you have to take the watch to a CASIO authorized service.
