I've turned, pulled, pushed the knob to release the needle. I don't know how to release the stop motion knob on my sewing machine. Please help me.
SOURCE: bobbin threading
You may have put the timing out, however, try this before you despair too much......
Ensure the presser foot is firm enough for the fabric you are using and that it will not just pull through easily by hand with the foot and feeddogs together (as the needle ascends), or things will not proceed, and you will be stitching in the same spot.
Generally a setting of 3 seems to work for general purposes, but if you are using very light or very heavy fabric, a sample is always a good idea before you start in earnest....also match the needle to the work for best results.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
SOURCE: Hand wheel spins without moving the needle
I used to have an old Bernina that had an inner and outer hand wheel. Loosening the inner wheel disconnected the needle bar from the motor so you could wind the bobbin without running the needle up and down. It sounds to me like your machine has the same feature, but resistance on the needle makes the inner wheel loosen up. I don't know whether wrenching on it as tight as you can would be enough, or whether this is a symptom indicating that there is something loose internally in the connection between the inner and outer wheels. Good luck!
SOURCE: Manual wheel on side of machine won't move needle
hi there;
well try to rotate hand wheel center holder clockwise while hold grift the handwheel not to move to engage the clutch,because ther is clutch that holding the movement of the needle and the bobbins case.if still nothing change at all,open a cover motor assembly chech the belt tension if still engage on pulley,maybe slip pulley is occuring when motor run,if belt is slip to pulley replace belt,but if ok upon clutch adjustment ignore replacement.
regarding bobbin and threading you can watch on youtube.doing this,on internet explorer,type www.youtube.com
then on you tube search type"sewing machine"then click search
ther are high ligthed show for bobbins winding and treading just click it enjoy watching while you learn,have a nice viewing regards
don't forget to rate me,thank's
SOURCE: motor is fine, but won't sew
since the machine has been setting for 20 years, it needs to be serviced
the old grease & oil have probably turned the gunk. the servicing can also tell if any parts are damaged
SOURCE: Sewing machine handwheel turns and whirrs but needle bar stuck?
my suggestion is that the machine needs to be serviced at a sewing machine shop, because for 1.it's not responding 2. it used & you don't know when the last time it was serviced 3.something is wrong with the machine.
hopefully there are no broken parts, but having the machine serviced will tell that.
as for a manual
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w510 ) & click search
