Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Posted on Jun 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have problems with mitsu wd-52327
Just replaced the lamp did everything manual said to do to change lamp. turned tv on great had picture for about one day. while watching tv went black red lamp light flashed then tv shut down. pulled the bulb appears to be fine. put bulb back in tv turned it on green light came on but still no picture then red light kicks back on and tv shuts down dont know what the hell the problem is. hopefully someone can help.
Anonymous
Level 3:
  • Master 822 Answers
  • Posted on Jun 04, 2009
Anonymous
Master
Level 3:
Answers
822
Questions
Helped
240285
Points
2570
Check the current maybe high voltage occur or due to loose connection high amper occur.
I have to change the lamp on my mitsubishi dlp tv. where is the lamp located?
Here is a link to the owners manual for lamp cartridge replacement. Specifically go to page 65 for instructions. Good Luck : )
http://support.mitsubishi-tv.com/files/oguide/WD-52327.pdf
I have a 2005 52 inch Mitsu turn it on and it goes to red light
di you replace the power for the lamp in your manul it will show you the lite set for your tv it it will give you i ideal what wrong. i see so with bad power supply or
the balstor go bad to i chang lamp bastor frist. when
the lamp go bad it will show you it the lamp in front of dlp. i hope this help you out.
1helpful
Recently my wd-52327 said it needed new bulb(steady orange light). i had replaced the bulb 7 months earlier and didn't want to see the light so i reset the lamp timer. well the bulb blew the next time i...
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Solid Yellow light and blinking yellow status light after bulb replacement. TV wont turn on.
Sounds like Mitsu is getting sued left and right about their DLP problems. There is a potential overhaul if you contact their parts department.
Sound no picture
If you replaced TV lamp recently then check lamp cover and make sure to seat it properly.
Need further info, let me know.
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Sharpness
as for the sharpness if the picture has no adjustment and is maximum sharpness you cannot improve it.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
