Question about Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190
Trane XE 90 LED code 5 and code 9 (furnace).
I have a Trane XE 90 that was installed in Feb 2001. Yesterday, it stopped producing heat. This morning I checked my breaker box and saw that the furnace breaker had tripped. I reset the breaker and checked the diagnostic codes. The LED flashed 5 times, then flashed 9 times repeatedly. I replaced the Igniter (code 9), but the furnace does not come on and the LED still flashes code 9'', after initially flashing code 5. The blower does come on and runs continuously (I think it is the blower that circulates air thru the ducts. Any suggestions? It still gets cold at night in northern Ohio. Thanks.
  • 24 Answers
High limit is open try tapping on it gently
Posted on Aug 10, 2009
2 Suggested Answers
SOURCE:
  • 582 Answers
SOURCE: I have a Trane Xe-60 furnace about 19 years old.
THIS IS A COMMON PROBLEM WITH THE DOOR SWITCHES, MY FIRST ANSWER WOULD BE REPLACE THE SWITCH SECOND WOULD BE OPEN THE DOOR AND PUSH THE BUTTON IN AND SEE IF THE FURNACE WILL WORK. THIS SWITCH IS JUST A DOOR SAFTEY IF THIS WORKS. I HAVE TAPED A PIECE ON THE INSIDE OF THE DOOR WHERE THE SWITCH WILL HIT THE DOOR ABOUT A 1/4 INCH THICK AND SEE IF THIS WILL GET YOU RUNNING UNTILL YOU CAN GET A SWITCH
Posted on Oct 12, 2009
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
Trane xe 90 burner wont light
Bad igniter? Could be a safety control telling the furnace not to light. Check to see if the furnace has a diagnostic indicator. If so count the flashes and then check the diagnostics list inside the door or in the owners manual. This should narrow the problem down.
May 01, 2014 | Heating & Cooling
Will not ignite. LED Code 31
Could well be the inducer motor Google carrier 31fault code there are 3 video's on this on u tube
Jan 15, 2018 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a Trane 90XL installed in 2001which has been running great for 10 years. Now in very cold temperatures this week there is water seeping from the base of the unit. Water is slightly yellow/green in...
Make sure all of the condensate lines are open. The Hose and traps from the furnace. With the cold weather the Furnace is running alot more and Condensing more water from the Flue Gases.
The Furnace can produce up to 5 Gals of water in an 8 hour period. If the drains are all open then you better get a professional to check out the furnace you could have a cracked secondary Heat exchanger which could be leaking carbon monxide into the house. Do you have a CO2 Detector in the house??
Jan 21, 2011 | Heating & Cooling
I have a Trane xe 70. The Heat is not turning on. The ignitor will glow but NO gas or blower. I turn on the fan and the blower does work but not when HEAT is selected on the t-stat. Also the LED light...
Check to see if you get 24 volts AC at the gas valve from the circuit board when the igniter is glowing. If yes, bad gas valve or blockage in gas train. If no, bad circuit board or broken wire
Feb 07, 2010 | Heating & Cooling
What is the efficiency rating on the Trane model BLU055E936B1 upflow furnace and what new furnaces are available to replace this old Trane furnace without having to change the venting system.
Chances are you need to replace both the condenser and furnace, then you you should get a varaible speed blower with the new furnace, get at least a 90% gas system with a 16 SEER condenser, save on energy cost as soon as it's installed. Go Get IT
Jan 28, 2010 | Ruud Central System Air Conditioner
Trane xe 1200, can i use the heat blower with out a working compressor, i need heat not air, thanks
you can switch the thermostat to "emergency heat" which will turn the outdoor section off and the thermostat will control the electric heat elements in the air handler if it has them.
Oct 19, 2009 | Omega Trane Furnace Draft Inducer Blower ...
I get 4 blinks it say open limit switch what does that mean
Your induce fan motor senor is out. The little fan motor that take out the heat has a sensor that tells the furnace thats its working. Some time it get stuck. Try blowing and sucking into the tube. you should hear a click
www.fastacservice.com
Oct 16, 2009 | Goodman GMS90703BXA Heater
Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190 Logo
2,200 people viewed this question
Top Omega Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
