3Com Wl-561 3crwe776075 Poe Access Point Logo
A
Anonymous Posted on Jan 31, 2014
Reset default ip - 3Com Wl-561 3crwe776075 Poe Access Point
Hmm
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Help me with my wep key please
2helpful
I just received a new modem from my cable company and now my router doesn't work. I tried resetting it and it still doesn't work. What do I do next
Reset password of DGS3627 from console
Wanted to set password om my linksys
192.168.2.1
192.168.1.1
1helpful
New password wifi
Lynsksy E1200 tried to reset. my passord and network name are of no assistance. After running software, router is not found. Tried using "admin" for both but nothing works. Please advise. ...
2helpful
Forgot my password and cannot reset?
1helpful
I have Dlink 615 model router. i reset one time and now i want to change again my name and password but i cant log into. I try admin in with the IP address and also my user name and password but i cant get...
When you reset your router the IP address will revert back to its factory default IP address and access information, if you changed the IP address prior to the reset you will have to use the default IP.
default IP: 192.168.0.1 (make sure that your network cards IP address is somthing similar like 192.168.0.2 and not 192.168.1.2)
Default username: admin
Default pass: leave blank
If you are still having issues let me know.
Top 3Com Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
