Magnum s 380 just quit no lights or nothing - Magnum S380 Amateur 10 Meter Radio, AM/FM Radio, 80 watts, Front Panel 4-Pin Microphone Jack, Variable Power Output Control, TURBO Digital Echo with Dual Controls, AMT All Mode Talkback with Volume Control on Front Panel, Front Panel Band Switch, High SWR W
Could be a bad capacitors. Open up the case and see if you have any bulging caps. The second thing I would try is to remove all the ram and reseat each ram stick. The 380 can be fickle about ram placement.
This was a recall issue that was supposed to be fixed, I would bring this into the dealer, they should fix it for free. They had electrical problems with these models, headlights dash lights, and sometimes wipers etc. I would get this checked out before your car brakes down on the road. Hope this helps and good luck. you can also refer to lemonlawclaims.com to check out a few other people that had this issue reported it.
