SOURCE: is the sony vaio vgn-nr120e a 64-bit?
Hi, the processor of the this model Vaio is Intel Pentium Dual-Core T2310. This is a 64bit processor which means that it should support a 64 bit operating system. Whether it will come with a 64 bit operating sysem, depends on your order.
Here are two links with the processor specifications and the Vaio specifications:
http://ark.intel.com/Product.aspx?id=32431
http://www.clearanceclub.com/products/8959-VAIO-VGN-NR120E-S
If you already have one, you can check if it is a 32bit or 64 bit by clicking on: Start/right click Computer and select properties.
Regards,
Purito
SOURCE: TOUCH SENSOR A/V CONTROLS NOT WORKING,VGN-CS325J
Install the Synaptics® Pointing Device Drive, VAIO Control Center Software, VAIO® Launcher Software,
Setting Utility Series and VAIO® Event Service.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS220J&upd_id=5122&os_id=48
restart the Computer.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS220J&upd_id=5008&os_id=48
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS220J&upd_id=5078&os_id=48
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS220J&upd_id=5000&os_id=48
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS220J&upd_id=5021&os_id=48
SOURCE: How can find; find Sony
You can download the device drivers from the Sony WEB site.
Select your model notebook and the Windows XP or Vista drivers
you require.
Please click on this link to the Sony support WEB site :-
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
SOURCE: my laptop (sony vaio VGN-CS325J)
Hi kufreudokang,
The VGN-CS1xx, VGN-CS2xx, VGN-CS3xx computer models have a known issue that the cooling fan in the Computer may make continuous scraping, whirring, chriping and/or clicking noise while running. As a part of Sony's commitment to quality, Sony provides a free repair for an additional 36 months beyond the standard limited 12 month warranty (48 months total) for fan replacement.
As you're experiencing the issue, you can contact Sony Support at 1-888-476-6972 to set up a repair service at our Sony repair facility.
Hope this helps.
Please post back if you require further assistance.
Thanks for using FixYa.
SOURCE: my laptop (sony vaio VGN-CS325J) fan makes a
This means that the micro ball-bearings are on their way out if the bearing race smashes then the fan will stop I suggest sourcing a brand new fan and fitting it yourself you might need a star drive look at the profile head of the screws.
http://www.fixya.com/support/r4730725-type_tamperproof_screw_tp3_torx_tri_wing
Make sure that both the mains supply and battery are removed, the fan will be a simple push to clip connection with only 2 wires.
