Computers & Internet Logo
e
edward lockerd Posted on Jan 31, 2014
Uninstaller internet
datatrax
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 63 Answers
  • Posted on Dec 25, 2014
datatrax
Contributor
Level 1:
New Friend:
Cheetah:
Answers
63
Questions
0
Helped
15194
Points
64
Do not understand the question
Uninstall internet explorer 9
Hi fella, To uninstall Internet Explorer
The following instructions apply to both Windows 7 and Windows Vista.
  1. Click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.jpg, type Programs and Features in the search box, and then click View installed updates in the left pane.
  2. Under Uninstall an update, scroll down to the Microsoft Windows section.
  3. Right-click Windows Internet Explorer 9, click Uninstall, and then, when prompted, click Yes.
  4. Click one of the following:
    • Restart now (to finish the process of uninstalling Internet Explorer 9, and restore the previous version of Internet Explorer).
    • Restart later (to wait until you shut down or restart your computer). BOL !
tip
Removing IE 8
<p>If you have problems with Internet Explorer 8, you might want to try <a href="http://support.microsoft.com/kb/956197/LN/">Compatibility View</a> or our <a href="http://support.microsoft.com/gp/pc_ie_v8intro">guided help</a> <span> </span>to see whether you can fix the problem. However, if you just want to uninstall, or remove, Internet Explorer 8, this article helps you do that.<br /><br />When you remove Internet Explorer 8, your earlier version of Internet Explorer is restored with your customizations (such as add-ins, Favorites, and your home page).<br /> <p><b>Resolution:</b><br /> <p>To uninstall Internet Explorer 8, follow the instructions for your version of Windows. To follow these steps, you must be logged on to Windows as an administrator<br /> <p><b>Important:</b> You cannot uninstall Internet Explorer 8 if it is set as not removable. This occurs if you install Internet Explorer 8 before you install Service Pack 3 (SP3) for Windows XP. If this scenario applies to you, then you must uninstall SP3 before you can uninstall Internet Explorer 8. For more information about this issue, click the following article number to view the article in the Microsoft Knowledge Base: <br /> <p><a href="http://support.microsoft.com/kb/950719/">950719</a> You cannot uninstall Internet Explorer 7 or Internet Explorer 8 after you install Windows XP Service Pack 3<br /> <p>To uninstall Internet Explorer 8, follow the instructions for your version of Windows. To follow these steps, you must be logged on to Windows as an administrator. <br /> <p><b>Steps for Windows 7</b><br /> <p>To uninstall Internet Explorer 8, follow these steps: <br /> <p>1. Close all programs. <br />2. Click StartCollapse this imageExpand this image, and then click Control Panel.<br />3. Click Programs and Feature.<br />4. In the tasks pane, click Turn Windows features on or off.<br />5. In the list of windows features, clear the check box next to Internet Explorer 8.<br />6. You receive a warning message in a pop-up window. Click Yes.<br /> <p>Internet Explorer 8 will now be uninstalled. The system will restart after the installation. <br /> <p><b>Steps for Windows Vista or for Windows Server 2008</b><br /> <p> loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> Close all programs. <li> Click Start</b>, and then click Control Panel</b>. <li> Click Uninstall a Program</b> under the Programs</b> category <li> In the Tasks pane, click View installed updates</b>. <li> In the list of installed updates, double-click Windows Internet Explorer 8</b>. <br /><br /><b>Note:</b> If Windows Internet Explorer 8 does not appear in the list of installed updates, try the <span><b>alternative steps for Windows Vista or for Windows Server 2008</b></span>. <li> In the Uninstall an update</b> dialog box, click Yes</b>.<br /><br /><b>Note:</b> If you are prompted for an administrator password or for confirmation, type the password, or click Continue</b>. <li> Follow the instructions to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer. </li></ol> <p><b>Steps for Windows XP or for Windows Server 2003</b><br /> <p> loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> Close all programs. <li> Click Start</b>, and then click Control Panel</b>. <li> Click Add or Remove Programs</b>. <li> In the list of currently installed programs, click Windows Internet Explorer 8</b>, and then click Remove</b>.<br /><br /><b>Note:</b> If Windows Internet Explorer 8 does not appear in the list of installed updates, try the <span><b>alternative steps for Windows XP or for Windows Server 2003</b></span>. <li> Follow the instructions to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer. </li></ol> <p><b>Alternative steps</b><br /> <p><b>Alternative steps for Windows Vista or for Windows Server 2008</b><br /> <p> loadTOCNode(3, 'moreinformation'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> <p>Carefully select and then copy the following command: <br /> <p><b>FORFILES /P %WINDIR%\servicing\Packages /M Microsoft-Windows-InternetExplorer-8*.mum /c "cmd /c echo Uninstalling package @fname && start /w pkgmgr /up:@fname /norestart"</b><br /> <li> Click Start</b>, and then type <span>Cmd.exe</span> in the Start Search</b> box. <li> In the list of programs, right-click Cmd.exe</b>, and then click Run as administrator</b>.<br /></li></ol> <li> Right-click inside the Administrator: Command Prompt window, and then click Paste</b> to paste the command that you copied in step 1. <li> Press ENTER to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer.</li> <p><b>Alternative steps for Windows XP or for Windows Server 2003</b><br /> <p> loadTOCNode(3, 'moreinformation'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> <p>Carefully select and then copy the following command: <br /> <p><b>%windir%\ie8\spuninst\spuninst.exe</b><br /> <li> Click Start</b>, and then click Run</b>. <li> In the <span>Open</span> box, type <span>Cmd.exe</span>, and then press ENTER. <li> Right-click inside the Cmd.exe</b> window, and then click Paste</b> to paste the command that you copied in step 1. <li> Press ENTER to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer.</li> <li> <b>More Information:</b></li> <li> After you uninstall Internet Explorer 8, you may notice Application event log errors after each reboot. To resolve this problem, delete the following Internet Explorer User Accelerators and Internet Explorer Machine Accelerators registry keys in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\GPExtensions: </li> <li> {7B849a69-220F-451E-B3FE-2CB811AF94AE} {CF7639F3-ABA2-41DB-97F2-81E2C5DBFC5D}</li> <li> <b>The information in this article applies to:</b></li> <li> Windows Internet Explorer 8</li></ol>
on Mar 15, 2011 • Computers & Internet
tip
For All XP user Don't Use IE 7.0 & higher version
Applicable for all window XP (all edition, all PCs and Laptops)
If you are getting trouble after the updates of internet explorer..
Then I would suggest you to Roll Back it to the original Internet Explorer (i.e Internet Explorer version 6.0)
Which come up with Installation of Win Xp with Service Pack 2.
Bad Effect due to IE 7.0 or higher version:
Screen hang up, internet freezes abruptly, prominent windows crashes anytime.
So to stop these problems, better to run with lower and safe version of IE:
To remove Internet Explorer 7 from your PC use the following methods
Method 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
Step 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
a. Click Start, and then click Run.
b In the Open box, type appwiz.cpl, and then click OK.
c. In the list of programs, click Windows Internet Explorer 7, and then click Remove.
d. Follow the wizard instructions to uninstall Internet Explorer 7. Also remove if any updates under this entry found.
If you cannot uninstall Internet Explorer 7 by using this method, try Method 2.
Method 2: Use Spuninst.exe to uninstall Internet Explorer 7
Run Spuninst.exe to uninstall Internet Explorer 7
b. In the Open box, type %windir%\ie7\spuninst\spuninst.exe, and then click OK.
c. Follow the wizard instructions to uninstall Internet Explorer 7.
After you uninstall Internet Explorer 7, double-click the Internet Explorer icon to verify that Internet Explorer 6 is restored.
This will bring up you to run Internet explorer as it come up with the installation kit, which is safe and reliable.
Have Nice Surfing!!
Ellin
Recently I upgraded Microsoft Internet Explorer 8 to Microsoft Internet Explorer 9 and I am having problem with my Real Player, not able to download any program. So I wanted to uninstall Microsoft Internet...
Windows Internet Explorer 9 has been installed as a system update in the operating system, and as such can be removed from the Uninstall an update control panel menu.
To get there click the start orb in the lower left corner of the screen, and then Control Panel in the right menu.
Locate Uninstall a program in the Control Panel and click on the entry.To uninstall Internet Explorer 9 click the View Installed Updates link in the upper left corner of the screen. This opens a listing of Microsoft updates that have been installed on the computer system.
Right-click on Windows Internet Explorer 9 and select uninstall from the context menu.
To complete the uninstallation, the computer needs to be restarted in the end.
After restart ur pc Run reginout cleaner to clean it's registry files
3helpful
2answers
I want to know on how to uninstall IE8 on my computer i am running a windows XP service pack 3. I just want to install a fresh copy of IE8 . . . . .
Hi josephc_agni,
  2. Click Start, and then click Control Panel.
  3. Click Add or Remove Programs.
  4. In the list of currently installed programs, click Windows Internet Explorer 8, and then click Remove.
    NOTE: If Windows Internet Explorer 8 does not appear in the list of installed updates, try the alternative step given below.
  5. Follow the instructions to uninstall Internet Explorer 8.
  6. When the uninstall program is finished, restart your computer.
ALTERNATIVE STEP:
  1. Carefully select and then copy the following command: %windir%\ie8\spuninst\spuninst.exe
  2. Click Start, and then click Run.
  3. In the Open box, type Cmd.exe, and then press ENTER.
  4. Right-click inside the Cmd.exe window, and then click Paste to paste the command that you copied in step 1.
  5. Press ENTER to uninstall Internet Explorer 8.
Explorer 8 removal
Steps for Windows 7 loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps:
  2. Click Start Collapse this image Expand this imagevistastartbutton.jpg, and then click Control Panel.
  3. Under Programs, click Uninstall a program.
Steps for Windows XP or for Windows Server 2003 loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps:
    Note If Windows Internet Explorer 8 does not appear in the list of installed updates, try the alternative steps for Windows XP or for Windows Server 2003.
Please rate the answer. Thank you!
Can not get on to my remote accrss since downloading ie8
Hi
Uninstall the IE8 and then your Remote internet would start working
How uninstall IE8
For XP
Start -control Pannel -add/remove programs - Check Mark View Install updates
find IE8 and uninstall IE8
For Vista
Start -control Pannel -Programs and Features -Left hand Top Coner View installed Updates
Uninstall IE8
Hussain .B
Added ie 8 beta, uninstalled, ie will not start
basically your ie8 uninstallation is bad...try and see if you can get an ie8 uninstallation toolkit at microsoft.com to uninstall ie8 properly. Else, you might have to reinstall ie7 after uninstalling ie8.. this same problem persisted when micorosft released ie7 and i was supporting ie7 when released. so take my word. happens with all ie beta versions..
Top Antec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
