There are 2 diagrams listed, one is correct, match the listed wire colors to your car to choose the correct one.
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Purple
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
2.
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Green/Black
Car Radio Ground Wire: Chassis
Car Stereo Dimmer Wire: Gray
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Under the Passenger Front Seat.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Yellow
Right Front Speaker Negative Wire (-): Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Negative Wire (-): Black/White
Ignore the 1st post u had it listed as a Nissan
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
TT251 - July 14, 2006
2007 Harley-Davidson Smart Security System Dealer Quick Start Guide
The new Harley-Davidson Smart Security System (H-DSSS) provides a transparent security
blanket for the customer's motorcycle. The design allows for self-arming and self-disarming
automatically and provides a transparent security environment.
Operation
The system arms itself within 5 seconds after the ignition is turned off and no vehicle
movement is detected. The Hands Free Fob does not need to be present to self-arm.
The alarm is activated if the system detects motion or if the ignition is turned on and the fob is
not present. The system can not detect whether the fob is in range at any other time.
Because the system is not communicating with the fob all the time, current draw is lower
(.7ma), and battery life is extended.
When the fob is present the system will disarm after motion is detected or the ignition is
turned on. The Personal Identification Number (PIN) may also be used to disarm the system.
The Smart security system will change the way the dealership interfaces with the vehicle.
The H-DSSS Impacts:
• Set-Up and Pre-Delivery process
• Service writers
• Transportation of motorcycle
• Servicing of motorcycle
• Customer expectations
Set-Up and Pre-Delivery Process
During Set-Up, the technician will need to use Digital Technician to assign the Hands Free
Fobs. The new bar code reader should be used to enter the 24 character number from the
bar code on the fob. Once assigned, the fobs should be tested immediately using Digital
Technician. The fobs have to be assigned and the PIN must be assigned to enable the
system. It doesn't matter what order this is done in. Since the system is self-arming, it is
absolutely important that the customer has the PIN and knows what to do (keep card) in the
event that the fob is lost or misplaced.
Tech Tip: Save the sheet that is attached to the carton when vehicle is uncrated and scan in
the bar code to fill in the VIN when starting the process with Digital Technician.
Service Writer - 2 choices
• Fob stays with vehicle
• System gets put into service mode
When vehicle comes in for service, make sure the keys and fob stay with the vehicle. For
vehicles that do not require the key to turn on the ignition, tie-wrap the fob to the mirror to
keep it with the vehicle. Another option is to use Digital Technician to put the system in
service mode. Once the system is put in service mode, the security s
Below is the master help link
provided to go through belt routing diagram:---Timing belt, drive belt,
serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all
types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
