Why is there no "software update " in my IPad 2?
There are two ways to upgrade the iOS version of your iPad:
- via connecting the device to iTunes on a computer
- or directly from within the device, but only since iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update)
just go to: settings - general - software update
SOURCE: friend pressed update to ios 7 on my ipad 2
I suggest you let it download the updation file because usually there is no option to abort the download and if you do not want to install the update just decline the license agreement this will abort the install and you would be able to use the old version. Note: Once you have installed ios7 there is no direct downgrade available as Apple had stopped signing the previous versions.
SOURCE: how can i get my ipad 2 out of recovery mode
I assume you did reboot. After that I would try to update again.
:) Hope this works for you.
