The water is filling when not on
SOURCE: Aqua Smart washer says, "clean cycle" need after 125 washes. How do I do that?
It's under the "lifestyle" section of the wash selection menu. It was called "Clean me" on my machine
SOURCE: My Fisher and Paykel EcoSmart top load washing
I am assuming that you have already made sure that your hot and cold water taps are fully open.
If not, then check those first.
Otherwise try this.
First, turn off the hot and cold water.
Remove the hoses from the back of the machine.
Turn the machine to face you and do a visual inspection of the screens on both the hot and cold water valves.
If there are no screens, your valves may have lime and hard water deposits, or they are simply too weak to fully open. Generic, as well as OEM water valves are available on-line to replace them.
SOURCE: excellence smart drive fills up with water and then doesn't wash
Hi just read your posting. Now when the machine stops does it sound a beeping sound and a series of lights light up? If it does starting from left to right I need to know what light have come on in the row of 8 lights.Is it the 1st and 5th or 3rd and 7th etc.Please reply 4 further help.
SOURCE: error code 49 on fisher and paykel 8kg aqua smart
Hi just read your posting.Error code 49 means the computer has measured a voltage from the valve diagnostic circuit that indicates the cold valve is faulty.Would you like help in confirming that the cold valve is faulty?You need an electrical test meter.Please reply and I can guide you thru the testing procedure.Looking forward to your reply.
SOURCE: fisher@paykel aqua smart washer shows fault code49.
Fault 49 on F&P agitator models is bad cold water valve or wires on it disconnected.
