Precor Error 05, Key Depressed at Power Up
Probable Cause
1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
This link will take you to the starting point for the parts for this manufacturer. You will need to narrow your search according to the model and serial number of the machine.
Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH...
Sounds like one of two things...
1. Somebody spilled somthing or got some sticky junk in there and one of the keys is semi gummy.
2. The machine got banged around once too many times and one of the connections is slightly ajar.
So basically it sounds like it's hardware and not software, so you'll probably have to pull it apart yourself, or else take it to someone
