KitchenAid KGRA806PSS Gas Kitchen Range Logo
A
Anonymous Posted on Jan 31, 2014
Kitchenaid gas stove temperature reading is not right\
Oven reads 375 but does not get anywhere that temp. problem is intermittent.
5 Related Answers
A
Anonymous
  • Posted on Oct 10, 2008
SOURCE: kitchenaid gas oven
kitchenaid is the biggest piece of ****.
completely unresponsive to their faulty appliances
can someone start a class action ?
Anonymous
  • Posted on Jul 04, 2009
SOURCE: KitchenAid Gas Range Temperature Probe
We had the same problem, and we tricked it into running it's cycle be doing the following;
1. Wrap a wet paper towel around the probe, plug it in, and close the door. Then follow the temp. probe directions in the manual:
2. Set probe temp. at 130 degrees, then select a bake cycle. We selected convect bake.
3. Set oven temp for 275 degrees, but maybe any temp over the probe temp would work.
4. Then start. The cycle took 12 minutes to complete, and when it was finished, turn the oven off and then open the door and unplug the probe.
5. Now everything works fine.
jbleep
  • Posted on Aug 02, 2009
SOURCE: "set probe temp" flashing and beeping on kitchenaid wall oven
I plugged in the probe and stuck it into a pyrex measuring cup of water, set the probe temp to 165, set the convection (or bake) oven to 500, and turned it on. This allowed it to run for about 20 minutes, and cleaned out the probe jack. Works fine now.
Anonymous
  • Posted on Aug 28, 2009
SOURCE: Kitchenaid Superba Gas Range - Oven temperature problem
The problem is: the temp seems to be 'stuck' at 260 and will not allow any higher settings.
Calling KitchenAid proved to be unuseful. The manual did not have this item in the troubleshooting pages. Resetting the power does not help.
The SOLUTION:
There is really no problem besides that the temp display setting has been somehow set to be celsius (metric system) rather than farhenheit (english system). Changing this setting somehow can be easily touched off without knowing, thus the "I didn't do anything and yesterday it was working fine..." comment from family members.
The FIX:
Reset the temp display back to farhenheit (F). This is done by opening the oven door, then hold down the 'Broil' button until you hear a beep from the control panel. The same method may be used to change from Farhenheit back to Celsius.
Prevention:
I speculate the inavertent change of the temp setting is done while cleaning the flat control panel. So the best thing to do is to always 'LOCK' the control panel when cleaning the controls. This is done by holding down the keypad "3/lock" for a few seconds until the display shows LOCK.
(The solution was already posted when I arrived at this page. I just organized it a bit by adding some details and a preventative comment. Many thanks to those who posted earlier, solving my issue as well. I hope my writing presents a clearer and quicker read to the next person)
Anonymous
  • 43501 Answers
  • Posted on May 15, 2010
SOURCE: KitchenAid KGRT607 - Oven won't light reliably, can smell gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
1helpful
How do I replace oven temperature fuse on a Kitchenaid Superba gas oven Mod.#KGST307HBS6?
have looked at the schematics can't find a fuse anywhere
see all parts here...
Kitchen aid made by whirlpool.. http://www.appliancepartspros.com/parts-for-whirlpool-kgst307hbs6.html
bad temp sensor maybe?
4helpful
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
1helpful
Oven will not reach desired temperature and slight gas smell
Just had same problem it was nice it waited until christmas dinner, all i did to resolve the problem was switch the upper broiler igniter with the lower one for the oven. I tuned on the oven & it fired right up i never use the broiler on my oven so itll buy me some time. So if you can get the broiler to light try that but i did have the same low temp. & the smell of gas. Good Luck
Hi,I have a kitchenaid gas stove and the oven does notwant to heat up. I have it on now for 20min,just barely warm.Any suggestions?
Most likely a bad glow bar ignitor at the oven valve. It must read 3 amps or more to activate the gas valve. Turn the gas off,put a clamp on amp meter on the ignitor wire and turn the oven on. If it reads less than 3 amps,replace the ignitor.
2answers
KitchenAid gas range superba not reaching/registering right temp.
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Amana Gas Stove M/N ARG 7302WW set temp. is higher than desired t
the oven safty valve is goin bad. that the part that most oven burners sits on.
2helpful
Tappan Oven overheats!!
If you have electronic controls, you'll need either the temperature probe (about $60.00) or the clock (about $150.00). You can test the temperature probe from behind the machine. It should read about 1080 ohms at room temperature. if the probe is good, replace the clock.
If you have mechanical oven controls, you need a new thermostat. Is the too high temp consistent? (i.e. runs at 375F +/- 25F?) If so, you can usually adjust the thermostat **** to read closer to the actual temperature.
Top KitchenAid Kitchen Ranges Experts
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
