SOURCE: problem in yamaha rx v800
Hello!!! Are you electronic technician? You should see the transistors Q22A, Q22C, Q19C e Q19A and its drivers on Main Board. All the best, Rasgador
SOURCE: Yamaha RX-V800 Remote Control
email me .... [email protected]... ill send
you a copy of the codebook page... but let me try and locate it first, i have the same unit before. Yamaha code books are the same also to other models.
Reden
SOURCE: yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
[email protected]
SOURCE: rx-v800
the capacitor is on the board that is on it's side (standing up as opposed to laying flat) it is the longest board it also has most of the input jacks housed on it. the supper capacitor is on the top side middle area and it looks like a button and is either blue or black. it is a .047F 5.5 volt super cap located at C633 part number WD294400 get it at www.vancebaldwin.com .
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
