Freezer on bottom, I think it is 480 litre. defrost heater not working and need model number to get a replacement element. sticker is missing from fridge and thought model number may also be somewhere else as well
SOURCE: hoover contour fridge leaking
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
Testimonial: "thanks, all fixed!!"
SOURCE: how can i check to see if the defrost is working
you will need to access the heater in the rear area of the freezer compartment and disconnect the heater element and take a continuity test of the element,if this checks good,then in the same area is your defrost timer,unplug the heater from it and hook up a voltmeter and energize the defrost timer manually and see if you have a voltage there
SOURCE: Hoover Contour HE423UFL fridge freezer continually frosts over?
I am on my fourth timer for this problem. Seems to fix the problem each time. You must remove the big chunk of ice covering the drain hole before you operate the fridge with the new timer. The contacts in the timer get burnt due to arcing inside the switch. The heating element seems to always work ok, but if the element is no good the fridge will not defrost.
SOURCE: Got a 9yr old w/house
If you cleaned it of all frost and ice and it keeps doing this then perhaps the defrost thermostat is detached from where it should be or shutting off too early. Try replacing it if is attached well.
SOURCE: I have a Westinghouse fridge freezer model number
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
For more of my tips go here:
https://www.fixya.com/SSL/myprofile.aspx#my-tips#my-tips
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
