I have the same problem with my voicemail reminder. It tells me there is voicemail when there isn't. I read the solution and just wanted to know if it worked.
I dont understand what you mean...I dont understand what you mean...
AnonymousJun 15, 2008
I have the same problem. Try reset setting but does not work. Still getting voicemail reminder popup.I have the same problem. Try reset setting but does not work. Still getting voicemail reminder popup.
You can't post conmments that contain an email address.
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
First of all you need to know the number you dial for voicemail. Make a note of this. Then, go to the dialpad and dial: *#61# and press Call. A box will popup telling you what the redirect to voicemail delay is. On my handset the default was 15 seconds. Now, dial: **61******SECS# and press Call where *** is your voicemail number and SECS is the number of seconds you want it to ring for before diverting. For example, on Vodafone UK the voicemail number is 121 so to set the ring for 30 seconds before diverting, dial: **61*121**30# Once the box has come up saying it was successful you can use *#61# again to check the setting.
The 6041 isn't an answering machine, so no, you don't have voicemail on the phone. If you're subscribed to a voicemail service offered by your telephone company, the phone is most like compatible with it and the phone is telling you that you have new voicemail. Please contact the telephone company for instructions on accessing their system.
Either the voicemail box isn't setup, the voicemail box isn't assigned to that extension, or that extension has forwarding setup that is incorrect. I have no experience with a Nortel phone system though so if you need specifics on how to get into those areas of your system to fix them you'll have to wait for another response.
The CS5113 isn't an answering machine. However, it works with the voicemail system offered by your telephone company. Please contact them for instructions on accessing their voicemail system.
Is the phone system working but the voicemail did not come back up ? Can you tell me what kind of voicemail you have, ist should be marked on the voicemail system ?
If u are getting these types of pop up then YoU need to contact 1.ur service provider's helpline and u will get the proper soltion whether there are any voice messages for you or not.
2.I f thereare no messages then reset the settings of your handset.1.Menu>>settings>>master reset>>reset settings (default code :0000) 3.After that if both solution doesn't work then scan ur handset with antivirus.
4.U just flash ur handset from service centre of LG
