I have a Mitsubishi 65" DLP Model WD65C10. I blew a lamp and ordered a new one but now the colors flicker when the set heats up for a couple minutes. Some research lead me to believe I need to replace the light sensor (GP2S40) I've got a new one but I am unsure of its orientation on the board. The sensor has 2 dot on the bottom towards one side.
SOURCE: mitsubishi 52525 dlp capacitor problem red light after lamp chang
No the board youre refering to is the Power PWB which is encased inside the metal chassis block. You can get the kit that is for your model that has the capacitors and step by tep instructions on how to disassemble the chassis to accesss the Power Pwb. Heres the link to the kit you need if the lamp led is red.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
SOURCE: Growing number (now six) small green dots on right
Replace Light Engine, pretty soon you will have Dots All over screen with green and purple color. Call UED for price of rebuilt Light Engine 1-800-648-6657 ask for Melissa tell her ladywinn said Hi.
SOURCE: We are having white dots
That means you need to replace the Optical Unit Block/Light Engine.Dmd board has been known to cause this also, but most of the companys replace Dmd and optical unit.
PTS rebuilts Light Engines 1-800-844-7871
Encompass Parts Distribution List this Model /Parts 1-800-638-3328
Testimonial: "Thank you so much. I will follow up. We love this TV and can't imagine just having to toss it out. I'll let you know how we make out. Gratefully, es"
what error code is found if do self check?
SOURCE: hi, I have a Mitsubishi wd-57733 dlp tv that shuts down
Ballast is possible if repeated lamp failure but I have a solution I posted several times for this type of problem that works and is simple to try:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Testimonial: "Thanks SD, I will hook up the air tank and see what happens."
