My printer has started only printing the first three pages of any print of more than three pages. It stops printing, the tray light flashes but when I open and close the paper tray it stops flashing and the printer starts printing again but it prints the same three pages again! It is cycle 3 pages, flashing tray light,open close tray, same three pages.. Any idea how I can stop this and print more than three pages?
Check out the link. Printer problems It will only print 3 pages
SOURCE: Paper jam / Dell 1710n
Do this You want to check the paperpath so first run a test page you will hear the paper pickup if you stick your ear to the paper tray it should pickup paper within 2 clicks any more than that that means you would need to change the bottom roller and the pad on the tray to be safe, to print a job the printer is timed to do this so if your paper is not picking up in time it will jam (also your fuser the part that heats up the toner on the paper it has a time limit to heat up if it's slow or don't heat up at all you will get a paper jam plus if that happens take your finger and run it across the paper if toner on your finger it's you fuser
SOURCE: dell colour laser 1320c printer prints one page
in your printer properties set the paper size according to your printer paper size.
SOURCE: my dell 1320c only prints first3 pages of a pdf
I had this problem with open office text files - the solution was to change the Page format (go to Format>Page) and set the page format to A4.
