Possessive Form of a noun.
To express possession one appends an apostrophe followed by s ('s). That is the possessive form of the noun.
The paw of the tiger : the tiger's paw. Tiger's is the possessive form of the noun tiger.
When the noun is a plural ending in s, the possessive form could be ...s's or ...s'. Both forms are correct. If you are a student and your teacher insists on using one form rather than the other, do as you are expected. Once you start writing your own books, use the form that pleases you. It is just a matter of usage, and usage is changing all the time.
SOURCE: what is a possessive noun
To express possession (ownership) in English one appends an apostrophe (') followed by s
The nose of the moose can be expressed as the moose's nose.
The rule is straightforward. When the noun to which the ownership refers to is the plural, the rule can be applied as stated above append ('s). However if the mark of the plural is s (regular plural) some people want to use the rule above, some others say that the last s should not be written.
Eaample: The hind legs of the wolves can be expressed as the wolves's hind legs or the wolves' hind legs. In the first expression you have wolves's while in the second you have wolves'.
Both rules are correct, but nowadays the tendency is to use the second form. It is a matter of usage.
If you are a student follow what your teacher says. When you write your own books, choose the one you want, but if your editor insists on using the other one, you have a problem.
Abstract nouns.
There is no such thing as a possessive noun. It should be possessive pronoun.
